Question about Wowwee Robotics Mini Wrex The Dawg Robot Dog
Wrex the dawg repair for remote
Dawg works great remote stop working
Sony RMT-D187A stopped working!
1= change the batteries by new ones
2= clean the contacts cleaners with contacts cleaner
3= resolder the wires contacts batteries
4= retight the spring contacts batteries with pliers for better contacts
5= open the r.control clean the kepayds switch for dirty, oxide, and test for open, bad contacts.
6= try agan, if doesnot work go to the repair shop TV for fix it.
God bless you
Jul 19, 2012 | Sony Televison & Video
I actually have an 08 Dawg. I love it, but the back brakes have never worked correctly. I have taken it to two differnet shops and it works fine for one ride, then its back to almost no back brakes and...
If the brake adjustment is good for awhile but bad after a bit of use it sounds like thsomething is leaking brake fluid or they weren't bled properly to begin with. A GOOD shop would figure this out the by the second time.
http://www.parktool.com/blog/repair-help/hayes-reg-hydraulic-brake-service
Jun 13, 2011 | Kona Dawg Deluxe 2010
Kenmore remote control ceiling fan Model 689.116700 with variable breeze setting. Fan has always worked great but has stopped running and will not turn on. The simple things have been checked and the...
How about the remote can they be replaced? I just got the same fn from a friend that has been in box for 20yrs. All works fine but Im worried about remote going bad.
Jun 01, 2011 | Hunter 52" Ceiling Fan With Light And...
I cant connect multiple xbox 360 consoles to my wireless router, WTF dawg?!
Here is a great tutorial to Connect and troubleshhot your Xbox to a wireless network.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 19, 2011 | Belkin F5D8236-4 Router
Hot dawg garage heater circulating fan wont turn on.
it could be the sensor for the fan not working try jumping it out i take it tha *** lights up?
Jan 09, 2010 | Dayton 75,000 BTU Hot Dawg Heaters:...
2002 jetta key/remote does work....
Pry it apart with a butter knife. It takes a CR 2032 battery.
Instruction on how to program are in the owner's manual.
Sep 20, 2009 | 2002 Volkswagen Jetta TDI
Ceiling fan with light and remote stopped working
Hello jluiken,
The motor in the fan is going bad. Unfortunately it will not be cost effective to repair the item as you will be doing an overhaul on the main component. It would be cheaper for you to just purchase a new one. If you leave the fan on for a long period of time you will see that it will become hotter and hotter, which could be a fire hazard so please be careful. Sorry for the bad news.
If you do not mind, please rate my help, I would greatly appreciate it.Thanks
Jul 04, 2008 | Dryers
Trans will not disengage
either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
Mar 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Not enough agitator action.
sounds like you need a set od AGITATOR DAWGS. part number 80040. located with iin the agitator it self. with the heel of your hand hit the fabric softener sectio off agitator. reach down inside agitator and remove the opaque seal. under there is a 7/16 bolt. this will release the agitator all together, tip it over and hte inner workigs should fall out. the dawgs are small plastic "gears". should be self explanitory at this point . reassemble, and you just saved about $150
Mar 12, 2008 | Washing Machines
Wowwee Robotics Mini Wrex The Dawg Robot Dog Logo
51 people viewed this question
Top Wowwee Toys Experts
Michael Vincent Cruz
Shekar Avadhani
Tom Chichester
Are you a Wowwee Toy Expert? Answer questions, earn points and help others
