Question about Audio Technica Audio-Technica ATM89R Professional Microphone
Audio technica atm89R
Repair solder
I need a wiring diagram for the mic end of a audio technica at822 the wires all broke at the solder points
This is the only thing I could find online:
1 - shield
2 - left (hot)
3 - left
4 - right (hot)
5 - right
Apr 09, 2015 | Audio Technica Audio Players & Recorders
How to dissasemble Audio Technica earworn mic connector? Need to repair Audio Technica earworn mic with damaged cable.
You probably can't disassemble the factory connector. What you CAN do is find a replacement connector (internet) that's designed for retrofit to your cable and install it on the good section of the cable.
Feb 19, 2018 | Audio Players & Recorders
Change battery on ATW-T210a
Here's the owner's manual for that series. You'll find the battery replacement instructions on page 6: http://eu.audio-technica.com/en/resources/2000a%20Series%20Owners%20Manual.pdf
Nov 12, 2013 | Audio Technica Audio-Technica ATW-T210...
I have several microphones, one's Audio Technica ATM61HE hypercardioid mic, and it has (low) volume issues. i brought it to audiophile before, they don't have the spare part on hand though, and the part's...
You might consider sending it in to Audio technica for repair. They're really customer oriented and alot of times they'll repair and or replace for just cost of shipping. Try contacting them directly.
Apr 30, 2011 | Audio Technica Audio-Technica ATM61HES...
Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Mar 31, 2010 | Audio Technica Audio-Technica AT2020...
Audio technica microphone atm33a socket detached
Unfortunately you will have to contact them here:http://www.audio-technica.com/cms/site/74a0c4b691ac33ae/index.html as they don't seem to have that document listed on their site.
Jan 10, 2010 | Audio Technica Audio-Technica ATM33a...
I have a audio-technica ATW-T51 and need to replace the cable as it makes a lot of noise. Where can I go?
to a web site called parts express.com you will find anything in audio related items there..
Nov 23, 2009 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
Changing frequencies on wirleless microphone
No, the ATW-R200 series are fixed-frequency units.
Short of soldering new crystals in, you're stuck with the frequency you've got.
Sep 21, 2009 | Audio Technica Audio-Technica 200 Series...
Disasimbel freeway atw-t202 for repair
might just be the mic wires came loose...I have oner and the mic is held in by a small rubber O-Ring and as people drop it it falls out and can short out
Jan 11, 2009 | Audio Technica Audio-Technica 200 Series...
Audio Technica Audio-Technica ATM89R Professional Microphone Logo
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
