Question about Cooktops
My John Lewis ceramic hob is locked and comes up with error code E R 0 3. I think the product code is JLBICH 602 ?? Please can someone help.....I'm starving!!!
  • 3 Answers
Press the two left buttons at the same time to reset or the two right buttons to reset if it doesnt work try oxfam
Posted on Jul 18, 2013
  • 93 Answers
SOURCE: Gagganau Glass Cooktop
www.foxatlanta.com
Posted on Jul 21, 2008
  • 338 Answers
SOURCE: hob not working
replace the hob. the f1 error is not sensing a temp change and if the burner is broke it wont sense it.
Posted on Dec 07, 2008
Maytag317
  • 1136 Answers
SOURCE: TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
Posted on May 18, 2009
  • 254 Answers
SOURCE: I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Posted on Feb 06, 2010
SOURCE: Stoves 700CTH hob
Hi, this worked for me as well on a 900CTH. Has to be a design fault judging by the number of people with the same problem.
No idea what this capacitor does but a guess would be that it is the reset circuit for the processor. This is normally a simple CR circuit which holds the reset pin down so the processor resets on power up. Only in this case their design does not hold the pin down long enough hence increasing the capacitor from 220 to 1000 micro-farads increases the time constant so that the pin is held down long enough. The installed value probably works well initially but due to the heat on the hob the capacitor ages, capacitance decreases in value (a common issue with electrolytics) and low temperatures at start up exhibit lower capacitances hence the fault is, as reported, worse in cold conditions. So my additional advice would be to pick a replacement with a high temperature rating.
Posted on Apr 07, 2010
UNLOCK THE LOCK OF CHILDREN IN CERAMIC
Hi and welcome to FixYa,
I can not insert the symbols here to properly answer your question so, I found the manual and you can read the steps on page 9 here:
http://awadnahas.net/pdf/UserManual/bf7e9e9b-cc9e-46fc-94a7-5965a2d61b18.pdf
This is copy and paste from the manual and the symbols will not come out:
Switching off the child safety device
• Start the hob with ( ' ). Do not set the heat settings . Touch for (Up arrow) 4 seconds. The
symbol ( 0 ) comes on.
• Stop the hob with ( I )
The symbols I typed above are not 100% as they appear in the manual.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | AEG HK955070CB 41 in. Electric Cooktop
Hey, what can I do if on a ceramic hob there is no error message but a letter "L" at each section? The control buttons don't respond I only can switch off and on again but nothing happens. Please...
You've probably accidentally activated the child-lock "L". It would help to know which model you have as the deactivation method can vary on different models. However, this is the process for activation or deactivation on the EKI-848 which looks like the one in the above picture:
Switching off the childproof lock
1. Press the ON key.
2. Then immediately press the Plus key of the cooking zone at the left-back and the Minus key of the cooking zone at the right-back simultaneously.
3. Then press the Minus key in order to deactivate the childproof lock. The "L" will go off.
If this doesn't work or you have a different model, please post back and I will let you know the correct deactivation method for your model.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | Kuppersbusch Glass ceramic induction hob...
Feb 05, 2010 | Cooktops
My soup spilled over on to my whirlpool ceran cooktop and i cant get the stains off. Is there a way to do it?
Is this a ceramic hob? If it is, you will need a ceramic hob cleaner (john lewis does one) OR Astonish oven/pan cleaner, a non-scratch washing-up sponge and a fair amount of elbow grease. This works for me.
Oct 05, 2009 | Whirlpool RCS3014 Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Candy sprinter
Great.. finally. i manage find from solution from user guide.. L is Locked. below is the instruction. will check out tonight.
The locking function holds the current settings, or prevents anyone from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on. To lock the hob : -Press the on/off button     . -Press simultaneously " - " button and " + " button of the front right zone (PVD 633 front left zone), and then press again on the " + " button of this zone. The hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds. To unlock the hob : -Press the on/off button      . The locking indicator " L " is displayed on all zones. -Press simultaneously the " - " button and the " + " button of the front right zone (PVD 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Jun 24, 2008 | Cooktops
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
250 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
