I have a hp f2483 that makes a tarrrrrrr noise before printing but prints well, how do i fix this
Same problem. f2483 is an inkjet printer and has nothing to do with toner cartridges, transfer rollers and fuser units.
Posted on Jun 12, 2012
headstrong
  • 233 Answers
SOURCE: hp laserjet makes a continuous screeching noise when plugged in and will not print.
remove cartridge, does it do it?
Posted on Jan 12, 2008
  • 624 Answers
SOURCE: squeaking noise when printing
Probably, but you?re going to have to try to isolate the problem a little better. Typically this would involve removing side panels and such; however, you may just have a faulty consumable like a toner cartridge, fuser or more likely the transfer kit. I typically try to isolate the sounds location then try replacing some of the consumables in that area one by one. In your case if you can?t isolate the location I would start with the transfer kit since that has a greater chance of making noise. Let us know what you find out and please don?t forget to rate the posting when we?re done.
Posted on Feb 02, 2007
  • 624 Answers
This is a duplicate posting; here is the link to the active posting: http://www.fixya.com/support/t132706-squeaking_noise_when_printing
SOURCE: grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Posted on Mar 25, 2008
APremkumar
  • 564 Answers
SOURCE: HP 1720 I making a noise when printing.
    NOTE: Refer to the Testing section in this document for instructions on performing the tests.
  1. Turn the printer off, and then turn the printer on. The grinding or squeaking noise should not occur while the printer is initializing.
  2. Perform a paper path test. The grinding or squeaking noise should not occur because the carriage should not be moving.
  3. Perform a self-test to localize the noise.
  4. Check the printer for obstructions by lifting the top cover and making sure nothing is blocking the carriage movement.
  5. Check the paper path by following the instructions below:
    1. Remove all media from Trays 1, 2, and 3.
    2. Pull out any visible stuck paper.
    3. Lift the top cover, and pull out any jammed paper.
    4. If you are unable to free the jammed paper, pull out the handle of the paper knob, pull the knob away from the printer, and rotate it to remove the paper.
    5. Lower the rear access door by lifting up on the two rear door latches.
    6. Remove the back panel by pushing the two catches inward.
    7. Pull out any paper that may be stuck inside.
  6. Wipe down the milky white strip (see Figure 1) that the front of the carriage glides on with a clean, soft, dry, lint-free cloth.
Figure 1: Location of the white strip
bpp90119-1.gif Replace the whole unitgtabtop.gifIf the printer is still making a grinding or squeaking noise after following the steps above, replace the whole unit. See Whole Unit Replacement instructions, which are included with the whole unit replacement.
Testinggtabtop.gifUpon replacement of the whole unit, perform a Paper Path test and a self-test as described below to verify that the new unit is functional.
    Performing a paper path test
    1. Press the MENU button on the printer control panel until Diagnostics Menu is selected.
    2. Press ITEM until Perform Tray x Paper Path Test is selected.
    3. Press SELECT to perform the test.
    NOTE: The paper path test will terminate only when the paper in the tray being tested runs out or the printer is turned off.
    Performing the stand-alone self-test
    1. Press the MENU button on the printer control panel until Self Test Menu is selected.
    2. Press ITEM until Print Menu Map is selected.
    3. Press SELECT to perform the stand-alone self-test.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 31, 2009
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
Hp deskjet f2483 driver
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3964428&
Click the above link, select your operating system (win xp, vista , win 7, etc), and click next to proceed for the full driver download.
Regards.
Sep 12, 2011 | Office Equipment & Supplies
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
HP K8600 started printing in only yellow & black.
replaceing the print head aught to fix it, if not you might have a logic board problem.
Aug 18, 2009 | HP OfficeJet Pro K8600 Printer
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Printing noises
You need to recheck the fuser that you put in. It can only sit in a certain way and direction. If it is just a little bit off it will make that annoying noise. God bless.
Jul 30, 2008 | HP LaserJet 2840 Printer
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Squeaking noise when printing
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
Printer making funny noise and print is almost peeling off the page on the right side
Your problem is with the fixing film in the fuser assembly (HP Part #RM1-3044). The brown material you see is the plastic film ripping and peeling off of the hheating element.
Jan 23, 2007 | HP LaserJet 3050 All-In-One Printer
74 people viewed this question
jasbo
jasbo
