How do dimplex wall mounted night storage heaters work? Do they stop giving heat late afternoon and start charging or do they give out heat at same tine as recharging? Can you turn off during day and
Wall mounted
  • janiec6 Feb 24, 2012
    What I really want to know is..if I switch them off during the day say at noon, will I then be able to make the heat last longer..say put them on again at 6pm and have a couple of hours of heat instead of them being on all day and going off at 4pm?
  • Heating & Co... Master
  • 3,291 Answers
They charge at night on the cheap rate , and give out heat in the day you can release the heat slowly in the day.
Posted on Feb 24, 2012
Testimonial: "Thanks..will try that"
  • Paul Carew Feb 24, 2012
    Hi well the only way is to try it some heaters you can hold the heat back and use it later . Its what ever works best for you .
  • 417 Answers
SOURCE: Dimplex night storer, how does it work?
Are you setting the input to maximum and the boost to late? You do not say what size the heater is in either kilowatts or kilowatt hours eg 2kW or 18kWh. These heaters will tend run out of stored heat in the evening especially in colder weather.
Posted on Jun 11, 2008
SOURCE: My on switch is lit up red all the time
Hell Yes, my electric bill was 200.00 ave. a month last yr
Posted on Dec 17, 2008
SOURCE: My dimplex night storage heater is not heating up,
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Posted on Jan 19, 2010
SOURCE: How to install a wall dimplex thermostat to a
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Posted on Sep 21, 2010
walterkunesk
  • 683 Answers
SOURCE: Does a bathroom new installation Dimplex FX20V
It would be safe if you did it that way.
Posted on Sep 15, 2011
Hi I have a night store heater model 79168 in my new home and no idea how to use it!! Please help :)
Here is a good article for Dimplex, a storage heater manufacturer, that explains the the theory and how it works. I'm sure you will find it interesting. http://www.dimplex.com/storage_heaters#
Basically, thermal storage heaters heat ceramic bricks during off peak hours (during the night), store the heat to be used during peak hours (during the daylight hours), when electricity is more expensive per kilowatt hour.
Hope this helps you.
Apr 18, 2011 | Heating & Cooling
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
Wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Jul 16, 2010 | Heating & Cooling
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
Dec 19, 2009 | Dimplex Heating & Cooling
Hi, Last night none of the Dimplex storage heaters in my home came on. I checked the fuse box and nothing has been trippped. They were working fine the night before and I cant think of any reason why they...
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
Dec 15, 2009 | Dimplex DS5603 Heater
Dec 17, 2008 | Dimplex DS5603 Heater
Jun 08, 2008 | Dimplex DS5598 Mid-Size Heater
Early / Late boost in dimplex storage heater
The output setting if turned off isn't adjusting the temperature in the room automatically if its off,and by turning the output up is like turning up the heat.By turning the output switch on you can let the heater automatically control the heat.Still you need to monitor the adjustments to your liking and then you know how hot it will be when you come back into that room.
May 26, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
