Question about Candy AQW130 Front Load Washer / Dryer
How do I replace drum bearing on Candy Aquaviva1300
I want to know if there are any special tools needed to replace the drum bearing on my Candy Aquaviva 1300
    New Friend:
  • 3 Answers
<a rel='nofollow' href="http://www.pulmoll.de/">halsschmerzen</a>
Posted on Jan 28, 2013
3 Suggested Answers
  • 38 Answers
SOURCE: candy drum bearing replacement
if you are absolutely sure it is the bearing, you will need a special tool to pull the old one off and press the new one on. My advise is to have a professional repair person do the job.
The Candy front load machines have a three-pronged support at the back for the drum. This sometimes get cracked or broken, when this happens, you will have to replace the entire drum assembly as the support is riveted on to it.
The broken support causes the inner drum to rub against the outer tub, giving the impression that the bearing is bad.
Posted on Jun 15, 2008
SOURCE: Candy Aquaviva 1300 washing machine
fabrick condictioner drawer stays full can you help me bernie
Posted on Jun 08, 2009
How do i fit bearing to the drum ?
As you should know most bearing comes with instruction how to install bearings and some you could find instructions on line .
Most likely you need to use special tools or bearing installation and removal tools .
Most likely you could buy them from appliance parts stores or auto parts and major tool stores or online tool stores stores and as you should know there are many different size and shape of bearing tools.
You have to be sure what kind bearing tools exactly you need
Be sure not to damage the bearing and drum when installing and removing old one and installing the new bearing
Jul 10, 2014 | Hotpoint Aquarius WF210 Front Load Washer
HI THERE I have a candy aquaviva 800 washing machine and it seems to not want to drain all of a sudden, i have taken out the hose at the back and given a good wiggle and sat with it in a bucket while
Your drain pump is dead. Have a serviceman replace the pump. How old is the unit? If it's old enough that it has the old belt-driven style, have them check to see if the belt is stretched or broken.
Apr 30, 2012 | Washing Machines
Where do i buy candy go682 80 drum bearings
To the best of my knowledge (I have attempted to make the same repair to my own Candy GO682-80) it is not possible to replace the bearings as this machine uses a "sealed tub" design. That is, it is not possible to separate the two halves of the plastic tub because they have been permanently glued together instead of bolted/screwed. This probably explains why nowhere seems to sell a bearing kit for this model.
Feb 12, 2012 | Candy Washing Machines
How do the drum caseing come apart to change bearing on my candy go1482 washing machine
Candy GO1482 model is made by Hoover and the drum is welded shut. You can't replace the bearings (cost usually 10 GBP) and a replacement is 220 GBP plus vat. I've just been bitten and hurt badly over it. Next time buy Indesit, Hotpoint or Bosch.
Aug 10, 2011 | Washing Machines
I CANNOT FIND THE LINT TRAY/HOLDER ON MY CANDY AQUAVIVA 1300 WASHER DRYER. I FIND THE DRYER GIVES THE CLOTHES A DAMP SMELL WHEN DRIED. IS THIS DUE TO LINT BUILD UP?
This is usually located either near the bottom front, possibly behind a plate, or inside the rim of the drum. Check the user manual.
May 26, 2011 | Dryers
Candy aquaviva 1300 no heat while drying
disconnect the unit from the mains supply and remove the lid you will find a thermostat with a red button on it, press this and if you hear a click, problem solved to prevent fault reoccurring always let the dryer cycle finish its self as stopping it early can cause the heater box to overheat.
regards
Ian.
Apr 17, 2011 | Candy Dryers
Drum bearing
look to see if there are any tamper proof fasteners on the machine, if not then as long as you have torx head and allen wenchs with the other basic tools you should be good to go
Jan 31, 2010 | Indesit WA 125 Front Load Washer
Candy aquaviva plumbing
NO if it has two inlets then both are used buy a connector to connect both hoses together any diy shop will supply
Dec 20, 2009 | Washing Machines
Bearings that support the drum on my front load washer are making
It is replaced from the rear of the drum, beneath the pulley.
You need a bearing puller tool and some common sense.
Take photos as you work, that aids reassembly.
Jan 06, 2018 | Frigidaire GLTF2940ES Front Load Washer
Drum bearings
Removal of the front seal (just the side right next to the door needs to be removed) is a spring loaded wire. There is a special tool for it, but it can be done without the special tool. Other than that, mostly phillips head screws and a few metric bolts. The suspension shock absorbers have a tab you need to depress to push them out.
Aug 19, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Candy AQW130 Front Load Washer / Dryer Logo
229 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
