Will not print on demand. Printer keeps telling my I have a no paper feed which is not the case. Ronald Scott
  • 6,487 Answers
Can you please give us first the brand and model of this printer so we can help you better....
Posted on Oct 28, 2008
  • 849 Answers
Put some papers on manual feed, go to the printer properties and select manual feed.
or
re-install printer
    Master:
  • 505 Answers
Turn off the printer after taking the cartridge out.
Clean the roller with soft cloth.
Put the cartridge back and then try printing
If you are still getting the same error :
Open the printer properties window
Click on the Service tab
Then click on Service this device
Then one by one click on Clean cartrdridge, align cartridge and finally print test page.
If you are still getting the same errro:
Uninstall and reinstall the printer from Add/Remove program window
If none of the above steps worked then its time we get the printer checked by some technician. You can also open the rear side of the printer and using two pin clean any dirt or paper jam.
Thanks
  • 149 Answers
Try to reinstall the printer to the computer
Why does my hp laserjet 1020 keep printing 4 blanks after each printed sheet? HELP!
My solution already posted in FIXYA.. for the same complaint earlier.pl go through..
http://www.fixya.com/support/t10478324-printer_taking_two
You need to clean the paper pick up solenoid located at down right side ...gently remove & clean it as shown..best of luck..
Aug 20, 2014 | HP LaserJet 1020 Printer
Paper feed problem
Hi
This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
Daniel Scott
Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper will not feed
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 27, 2009 | Dell 962 Photo All-In-One InkJet Printer
Paper roller on the left side of printer will not feed the paper
Hope that helps!
Aug 26, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Thick paper won't print
check ur printer settings and try again if not soloves to and change the paper better to use thick paper
May 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Lexmark 4270 won't feed paper to print or copy!
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Good Luck
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Paper feed problem
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Lexmark X2350 All-In-One InkJet Printer
Paper keeps feeding
Just started happening yesterday to my HP printer as well....a virus maybe?
Jan 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
k24674
jasbo
jasbo
