Question about Nakamichi SoundSpace 9 CD Shelf System
NAKAMICHI SOUND SPACE 9
UNIT SAYS E-20. DOEN'T WORK AT ALL. CN'T EVEN OPEN DOORS. HAVE UNPLUGGED UNIT FOR 2 DAYS. STILL DOESN'T WORK. HELP! reneerotta@aol.com
SOURCE: NAKAMICHI SOUND SPACE 5
How much do you want for it. I could use the power supply from your soundspace 5.
Posted on Jul 11, 2008
SOURCE: Nakamichi soundspace 9 error 20 what is that?
Hi
I have the same problem as you have, can you please help me?
It appears always E 20, and I can not open it.
Thanks
maria
Posted on Oct 25, 2008
kman-k
  • 18 Answers
SOURCE: I BOUGHT FIX IT VERSION
HI
You need to uninstall Fix IT 8 not by deleting it but by uninstalling it through the control panel remove programs.
then install Fix IT 9
It should work fine
Cheers
Posted on Nov 28, 2008
SOURCE: Error e-20. Doesn´t Work anything related to the Cd Players.
The system may need to reset. Unplugged the amp from the power source completely and let it rest for at least 5 minutes.
The illumination can only be controlled from the main remote. Adjust the prongs inside the remote and this should fix the issue.
Posted on Mar 23, 2009
  • 4 Answers
SOURCE: Nakamichi Sound Space 8 System
NEW CABLE FROM NAKAMICHI IS £150 . INSTEAD JUST CUT THE METAL SHIELD OFF ANY CD MINI DIN CONTROL CABLE WITH A JUNIOR HACKSAW AND IT WILL FIT PERFECTLY (IT ONLY GOES IN ONE WAY BECAUSE OF THE WAY THE PINS ARE LAID OUT!). I USED AN OLD MAC DIN PLUG BECAUSE IT WAS 3M LONG! WORKS PERFECTLY!
DS
Posted on Mar 01, 2010
How do I open the cd drawer to remove a fallen paper clip
If you do a google search for "Nakamichi SoundSpace 9 service manual" you will see a PDF file that shows how to dismantle the unit so you can get the item out.
May 22, 2016 | Nakamichi SoundSpace 9 CD Shelf System
Would a nakamichi soundspace 8 subwoofer work on a soundspace 9. I think the power is the same. Thanks Hugo
Nop, don't do that, the subwoofer power in the Nakamichi Soundspace 8 is 20 Watts and the subwoofer for Nakamichi Soundspace 9 is 70 Watts. If you put the 20 Watts Subwoofer on a 70 Watts input the subwoofer will receive severe damage. http://www.nakamichi.com/pdf/SS8_brochure.pdf
http://www.nakamichi.com/pdf/SS%209%20Brochure.pdf
Jan 29, 2016 | Nakamichi SoundSpace 9 CD Shelf System
Ge Profile soap dispenser doen't fully open during wash
Pour boiling water into the dispenser, it may be gunked up with soap residue
Mar 21, 2017 | Dishwashers
Nakamichi Soundspace 5 will not turn on with the remote or the power button
The main fuse, or power transformer is open, or the audio output ic has failed. Since you were having trouble with the remote and power button I recommend replacing the item, cost to repair will be high.
Apr 14, 2012 | Nakamichi SoundSpace 5 Shelf System
Have had a Nakamichi Sound Space 1 music stereo system for 10 years. Has served me well but the other day when I turned on the wall switch the power light did not come on. have tried...
you should always check the plug 2 all your thangs an change them if they are faulty. try 2 plug it in someware eles. or the unit is done. somethang could be burnt out. dnt leave it plug in.and dnt plug it in 2 a multi plug. go staight 2 the wall to check any power problems.
May 10, 2011 | Nakamichi SOUNDSPACE 1 CD Player
Jul 28, 2007 | Nakamichi SoundSpace 9 CD Shelf System
When the wash cycle is complete, the door doen' open?
the door may be locked electrically, pneumatically or mechanically. if you unplug it and wait 3 mins see if it opens. if not keep unplugged and check the door lock from the inside to see if there is a tube connected to it- if so pull it off. if no go the lock may be jammed.
Jun 07, 2007 | Supra SW5L50D Front Load Washer / Dryer
Nakamichi Sound space 8.5 Home theatre system
check www.dalbani.com and see if you can get these parts.good luck.greeting from Belize my email is nicodhem@yahoo.com
Apr 04, 2007 | Nakamichi SoundSpace 8.5 System
Nakamichi SoundSpace 9 CD Shelf System Logo
129 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
