Question about HP ProCurve 2510 Switch 24-Port Gigabit (J9019B#ABB)
Default ip hp 2510
What is the dafault IP
eng_darwish1
  • 233 Answers
SOURCE: default hp 2015 password so I can change the IP address
make a cold reset or NVRAM reset
To do a cold reset you power on the printer while holding down the go button for about 5 seconds and then release the button. If the button is held for more then 15 seconds it may do a NVRAM reset
Posted on Jul 07, 2008
  • 61 Answers
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Posted on Jul 24, 2008
SOURCE: HP LJ p2015dn IP configuration using HP Toolbox FX
Hi Basically I powered up the printer unplugged the network cable. Reconnected and waited 2 min. Pressed green button till first sign of green light flashing. The printer then printed out a printout which shows ip address on first and third page. I then used internet explorer to change printer from DHCP settings to fixed. just type new ip address on internet explorer address line. PC and printer must be on same network.
Posted on Jul 28, 2008
SOURCE: HP LaserJet P2015n Printer IP adress
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
Posted on Sep 23, 2008
comment
  • 78 Answers
SOURCE: configure tcp ip hp 750c
Assuming the JetDirect card is installed and properly functioning, use the following. Also, you may have to update the rom on the I/O Card to the latest version.
  1. From the front control panel message, Ready or Ready to Plot, press ENTER.
  2. Press the Up arrow key until I/O Setup appears, and then press ENTER.
  3. Press the Up arrow key until Modular appears, and then press ENTER.
  4. From the front control panel message, Cfg Network=No, press ENTER.
  5. Press the Up arrow key to change to Yes, and then press ENTER.
  6. Using the Arrow keys, scroll to Cfg TCP/IP=No appears, and then press ENTER.
  7. Scroll to Yes, and press ENTER.
  8. Press the Up arrow key until BootP=Yes appears, and press ENTER.
  9. Press the Up arrow key to change to No. Press ENTER (When using BootP or DHCP, keep the setting BOOTP = YES *. The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect. No other TCP/IP configuring is necessary.
  10. Press the UP arrow once to get to the IP byte section.
  11. To change the IP byte, proceed as follows:
    1. Press ENTER.
    2. Press the Up or Down arrow key to change the number.
    3. Press ENTER.
    4. Press the Up key to continue to IP Byte2=xxx.
    5. Press ENTER.
  12. Configure the remaining bytes of the IP address in the same manner. A valid IP address is required for proper operation.
  13. Configure the subnet mask bytes (SM), syslog server IP address (LG), default gateway (GW), and timeout (TIMEOUT) by pressing the ENTER and the Up or Down arrows in the same manner as above. The timeout parameter default is 90 seconds. Up to 3,600 seconds can be configured. If set to zero, the timeout feature of the HP Jetdirect print server is disabled; TCP/IP connections will remain open until closed by the server.
  14. Press PREVIOUS repeatedly, until the Ready to Plot or Ready message appears. Refer to the HP Jetdirect Network Interface Configuration Guide to configure the network operating system.
  15. Press the Up and Down arrow keys simultaneously to save the IP address on a 750/755 plotter. (A page should print and the IP addresses will be saved.)
Posted on Nov 19, 2008
What is the default ip address for hp 2510-24 j9019B switch ?
Switches don't have an address, think of them more like a traffic intersection with 24 roads.
When you plug a device into the switch, that device gets assigned an ip address.
For example:
  1. Phone line comes in to your house and stops at your modem, your modem is plugged into the switch. The modem picks up the private network address 192.168.0.0
  2. Your computer is plugged into the switch. It picks up ip 192.168.0.1
  3. Your friends computer is plugged into the switch. It picks up ip 192.168.0.2
This carries on until you have filled all the sockets on the switch.
The ip's here are only on your personal network, to find what your external ip (your modem -> internet) is just type 'whats my ip' in the google search and it will show you your public ip address.
Nov 24, 2015 | HEWLETT-PACKARD Hewlett Packard HP...
What is the default ip address and user name and password for this product?
For example:
What is the default IP of HP ProCurve 2510-48 ?
There is no IP address when the switch ships from the factory. It is set by the user and/or the network by DHCP. If you do not know what the IP address was set to, then you'll need to return the switch ti it's factory default configuration. There should be information in the manual for the switch about the default config.
Jul 02, 2014 | HP ProCurve Computers & Internet
Factory settings ip
I believe there is no IP address when the switch leaves the factory. If you do not know it, then you may have to return the switch to its facrory default configuration which is outlined in the switches manaul.
Feb 05, 2014 | HP procurve switch 2510-48
Default ip procurve 2510 48
there is no default ip address on a procurve switch. you have to put an IP address on the switch. You can find a manual for your switch at http://www.hp.com
Oct 12, 2013 | HP procurve switch 2510-48
Ip helper-address
The IP helper-address is the IP address to your DHCP server on your network
Sep 30, 2013 | HP ProCurve 2510 24-Port Ethernet Switch
Ip address for a konika minolta di 2510 f
select you tube and ask how to set ip address for konicaminolta di 2510
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 11, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
I've lost the password to my router and I can't set up my computer
The dafault ip adresse is: 192.168.1.1
The dafault password is: 1234
Try this and let me know if it works
Jun 01, 2011 | Zyxel P660HW-D1 Router
I type in my belkin ip adress in the box to go there and every time it will say faliure to connect to webpage
You could have the wrong address, try the following.
Open up the start menu, windows icon bottom left.
Vista/7: In the search bar, type in "cmd" and hit enter.
XP: Click on "run", then type in "cdm" and hit enter.
Now you should have a black screen with white lettering.
Type in "ipconfig" and hit enter. Look for the mention of "Dafault Gateway". The IP listed there should be the address of your router. Type that IP in your browser.
If the above did not work: Connect the computer directly to the router via ethernet cable. Reboot the router then the computer in that order. If you are already connected via ethernet cable, finish off the rest of the steps.
Then repeat the above with doing a ipconfig to find Default Gateway.
Mar 31, 2010 | Computers & Internet
HP ProCurve 2510 Switch 24-Port Gigabit (J9019B#ABB) Logo
2,669 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
