I what to know the reset crystel of sansui 101184512531 system Ic
Hi what's the no. of the vertical output IC for sansui sv2118si?
Contact Sansui or purchase the schematic, I don't think your going to find anyone with the information you need on here as if it has a vertical out IC its a really old set.
Dec 31, 2017 | Sansui Televison & Video
I have sansui crt tv procceser 101184512531 no osd display please give ic data sheet there is using croma ic om8361
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "IC number" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Dec 17, 2016 | Sansui Televison & Video
Sansui smart TV keeps rebooting
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Nov 27, 2016 | Sansui Televison & Video
Sansui car radio automatic search does not work all the time
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
Oct 20, 2016 | Sansui Televison & Video
Sansui lcd tv will not search for channels it goes to the search screen for about 5 sec then goes back to channel 2
Try it after a hard reset. If it do not help you, check and replace its main system control memory IC.
Mar 05, 2013 | Insignia IS 20" TV040919 TV
Sansui SV-2110K, Channel lock
Click here and try to download the user manual to your Sansui TV, and refer it how to make a factory reset to your tV. If it do not help you, the main system memory IC might be faulty, and should be replaced.
May 14, 2012 | Sansui Televison & Video
Board runs shows to be on runs but no beep and no display. No beep even when processor or memory removed.
The problem is in the processor or in the board to check first change the processor sutable for the socket and switchon the computer still the computer doesnt work check the secondery power supply thats four pin from the smps to the motherboard check all the FET and the capacitor in the powersupply also the 32khz crystel and the 14.182khz crystel and the clock ic
Mar 29, 2011 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
How to troubleshoot a mother board
to trouble shoot motherboard you need to know basic of motherboard there are mainly three thing s for motherboard to work first voltage +12v +5v +3.3v the motherboard then needs clock and reset to start adreesing the lcok is produced by the 14.318Mhz crystel and restet is produced by 32 khz crystel when the power is on first the clock has to be present for the reset to function if the clock and reset and there and the adress line is not still working means the elecrolitic capcitors are fult the capacitors in motherboard have huge role to play they are ones prvent audiolines entering the adress lines
Jan 29, 2011 | ASUS M2N-MX Motherboard
Sansui TVM1300 13 inch TV - Set Auto Channel does not work. I go into the Menu and start Auto Channel and it does not find any channels. Yet I can manually enter the channel number and it will go to that...
Sounds like AFT, AGC voltages are not proper. Contact any service technician. The main board of your TV has to be troubleshooted.
If the main system control memory IC is bad, this kind of fault can occur. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
May 19, 2017 | SansuiS3275 TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
