Question about Gateway GM5084 PC Desktop
No screen at power on
I have a gateway gm5084 desk top unit. When powered on the light on the monitor goes from amber to blue like normal but nothing is displayed on the screen. I have removed all pci cards modem and wintv, I have removed all but one memory card I have removed the dvd cable all usb cables,tryed different hard drive cable locations, in otherwords I have skinnied down the unit and have eliminated anything that could be holding it down. I have measured the voltages and have 5.06 for 5 and 11.64 for 12. I put another video pci card in. The original is on the mother board. Its acting like the bios is not even coming up. Looking for ideas.. Thanks
  • 2 more comments
  • wolfer1210 Oct 28, 2008
    ram has been changed or rotated and taken from 4 sims to 1
  • wolfer1210 Jan 08, 2009
    Replaced the CPU no help, replaced the motherboard and unit worked for 24 hours, turned off repluged in different location did the same thing
  • Lord vader Jan 11, 2009
    the power supply is way underpowered for the processor.
    i am trying a larger power supply
  • Anonymous Apr 28, 2009
    I have the same problem. The only work around I have found is to turn the computer off by holding down the switch and turning it on again, repeat about 5-10 times and it finally boots the bios...sometimes. I have also switched out the video card, cd drive, hard drive, and memory cards to no avail. Haven't tried the cpu or motherboard yet. Also the computer has gotten really sluggish and won't wake up quickly from screensaver state.
    I ran a bunch of diagnostic tests and they all say the computer is performing just fine.
  • 149 Answers
Your RAM probably went bad
Posted on Oct 28, 2008
  • matt Stahulak Oct 28, 2008
    if you have no video it usually means the ram or the cpu is bad..try the cpu? im not sure how to test them..
I was getting the blue screen for a few months, and now when I power my Gateway GM5084 the lights come on and I hear it running but nothing comes up on the monitor. It's like it's not connecting...
First I would try a different video card to see if your video card is faulty or not. If you still can't seem to get any picture it could be that the power supply on your computer is starting to fail and not providing enough power to the video card.
Usually your PC will beep if it is a video card issue so if you don't hear beeps I would guess the power supply is the culprit. A replacement power supply is not that expensive and is quite easy to install as well.
May 18, 2011 | Gateway GM5084 PC Desktop
I added a new video card and the monitor wont come on
1) Did you plug the monitor into the graphics card?
(Hey, happens! Sometimes in our zealousness to see what that baby will do, we mess up a little)
2) Did you install the Drivers? First?
These will be on the installation disk that comes with the graphics card.
Recommend installing the software from the disk FIRST, then turn the computer off, unplug from power, install the graphics card.
3) Does the graphics card require additional power?
Some graphics cards will not receive enough power, from the graphics expansion slot they are inserted into.
[Gateway GM5084 uses a PCI Express x16 slot, for best graphics.
http://support.gateway.com/s/PC/R/1009054/1009054nv.shtml
(Left-click on Specifications]
Some powerful graphics cards require additional power cables from the Power Supply.
Post in a Comment.
Sep 29, 2010 | Gateway GM5084 PC Desktop
Sleeps and won't wake up. unblug pwr supply won't shut down properly. when pwr supply is plugged back in, monitor like comes on blue then amber like in sleep mode. Nothing shows on monitor. ctrl /alt/del...
Hello
Thank you for using FixYa for your problem
Needs a techie toolkit disc to run HDD regeneration scan then try the repair mode in your install disc, (2nd repair mode)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Gateway GT5625E Refurbished Intel Desktop...
Pc wont turn on.
check the ram...clean it twise and try again..if it is not dissconnect cd drive cables and try once again.
Jun 24, 2009 | Gateway GM5084 PC Desktop
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Nothing comes up on the screen
The monitor connected to the system is set to receive video signals from the DVI port on the video card and it is not getting a signal.
Possible Causes:
  1. Monitor is connected via VGA (Blue Connector). Fix by using the input select button to select DVI input)
  2. The video cable is not connected to the correct port on the system (Or not connected at all)
  3. The monitor is on, but the tower is not powering on or failing to complete the Power On Self-Test (POST). It the power LED on the tower is NOT on, or solid or flashing Amber then the tower is not posting. Flashing amber is normally a bad power supply, solid amber is the motherboard.
Mar 01, 2009 | Dell OptiPlex GX280 PC Desktop
When i turn on the pc as soon as the screen or desk top pops up it turns black.
try to boot in safe mode and reduce your screen resolution to 800x600
Apr 17, 2008 | Computers & Internet
Gateway GM5084 PC Desktop Logo
158 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
