Question about Gigabyte GA-8IDXH Motherboard
Cant clear the BIOS for my GA-8IDX board
Shortening the jumpers seams not to work
  • Anonymous Mar 15, 2009
    i have problem with my motherboard. it turn on when the power is on!is there any problem in its circuit!? may be short circuit??
    Problem Solver:
  • 4 Answers
Remove your Battery & Short battery contacts for a minute & keep it about 20 minutes without battery. i think you cant repair your CMOS Jumper problem.
Posted on Oct 28, 2008
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
I want to upgrade my CPU capacity from 1.2 GHZ and want to know my motherboard so much support??? my motherboard is GA-8IDX (845 chipset)
If you go to CPU-Upgrade.com, you can see all of the different processors that are compatible with your motherboard:
http://www.cpu-upgrade.com/mb-Gigabyte/GA-8IDX.html
The ones highlighted in pink are not supported for your motherboard, the ones highlighted in orange may or may not be, and all the ones in white are compatible with your motherboard. It looks like you have several high-end options, up to 2.8 GHz.
Feb 13, 2011 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Hi, I messed up my BIOS by trying to update it... I got an asus p4b533 and cant find how to do a CMOS reset. I read about shortening two bumps because this board obviously has no jumpers to reset CMOS....
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine.
Hope this helps
Jan 16, 2011 | ASUS P4B533-VM Motherboard
I need update new BIOS for Intel 845 AGPSet BIOS for 8IDX F7 AWARD BIOS
You can download the motherboarddrivers and BIOS updates from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : -http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Nov 21, 2010 | Intel Gigabyte GA-8IDX 845 AGPset P4...
It cant boot but identifies my system components.It does not does not display setup page when i click on del key.
If your board has a Clear CMOS jumper,
follow the steps below:
1. Turn off power.
2. Disconnect the power cord from MB.
3. Take out the battery gently and put it aside for about 10 minutes (Or you can use a metal object to
connect the positive and negative pins in the battery holder to makethem short for one minute).
4. Re-insert the battery to the battery holder.
5. Connect power cord to MB again and turn on power.
6. Press Del to enter BIOS and load Fail-Safe Defaults.
7. Save changes and reboot the system.
If your board doesn't have such jumper, you can take off the on-board battery to leak voltage to clear CMOS.
Jan 20, 2010 | Gigabyte GA-8I865GVMK Motherboard
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Jul 27, 2008 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Motherboard
No Sound Support
Jul 18, 2008 | Intel Motherboard
Gigabyte GA-8IDXH Motherboard Logo
120 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
