Question about West Bend 41125 Hand/Stand Mixer
Unlock my w880i - West Bend 41125 Hand/Stand Mixer
Kitchen aid unlocks
By unlocks I have to assume that the mixer head can be lifted up during operation (yes that's really messy ans in some cases maybe even dangerous) I have to assume that you also mean the the head lock switch is not engaging, You have to take the mixer apart to re attach the mixer lock switch. There are several really good videos on youtube that shows step by step procedure for taking the mixer apart. you will see the switch when you have the mixer apart. tighten the screw down tight enough to make the switch engage again. Re-assemble the mixer.
Feb 11, 2013 | KitchenAid 32685 Mixer
Ksm90 mixer won't unlock
Look for a reputable dealer that repairs KitchenAid mixers. It is worth the little extra money to keep it going well. I had a much needed repair 15 years ago...... it was 8 years old then, and it is still in great shape and working superbly!!
Aug 15, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My 325 Watt Artisan mixer's adapter won't come off? How do I get it unstuck?
To remove the mixer attachment I belive you must press up on the attachment to lock the inside gear into place. Once it is locked into position you can now twist to the left to remove the attachment. once removed you can pull the shaft back down to unlock the gear.Hope this helps.
Thanks.
Nov 15, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Sunbeam Heritage Mixmaster Won't Tilt back
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Jun 12, 2009 | Sunbeam 2346 Heritage MixMaster Series...
The lock/unlock button will not lock. It remains
Without being able to see it try this. Unplug the machine. Place it on a towel on it's side and look up inside the base neck. There's a set screw at the top. Unscrew it 3 to 4 turns and twist the head as much as you can back and forth. See if it locks. Tighten the screw.
If not the pin may be bent to one side and won't drop into the slot. Does the pin lower with the head up? If it does take a pair of pliers and while viewing it from straight on bend it gently so it lines up with the slot on the neck of the base. If that doesn't work it probably has to come apart to see if the linkage is bent or has come apart inside.
Apr 11, 2009 | KitchenAid K45SS Classic Stand Mixer
The head to my kitchen aid mixer bounces up when kneading dough
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Apr 05, 2009 | KitchenAid Food Mixers
Replacement of lock and unlock lever
Look for my posts on "Removing the motor cover". The lock is under the motor head. Its easy to find and fix.
Jan 02, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Sunbeam mixmaster jammed, will not tilt back
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
Dec 28, 2008 | Sunbeam 2346 Heritage MixMaster Series...
West Bend 41125 Hand/Stand Mixer Logo
Top West Bend Food Mixers Experts
tfelton3
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a West Bend Food Mixer Expert? Answer questions, earn points and help others
