Question about Delta Plumbing
How do you remove the handle on a delta t17030 shower valve
I have a delta shower valve model number T17030 na I need to know how to remove the handle to repair the valve
2 Suggested Answers
  • 44 Answers
SOURCE: how to install Delta T17030 Innovations Collection
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevE_13943.pdf
New Install:
1. Shut off the water.
2. Remove Plastic rough-in spacer. It's black and it's only there for roughing in, and so the tilers don't come too close.
3. Unscrew silver retaining nut - should only be hand tight. Remove and discard grey cap that was being held is place by nut. Remove and discard plastic stopper inside faucet.
4. Take grey plastic disk off of cartridge and DO NOT THROW AWAY. Adjust gearing/splines to hottest temp by rotating plastic insert. Reinstall plastic disk.
5. Install cartridge with HOT lettering to LEFT. Secure with Silver Nut.
6. Slide large O-Ring over silver nut.
7. Install trim plate using long phillips(star) screws provided (2)
8. Slide Plastic spacer (looks like a snowflake) into chrome trim (cylinder) and slide cylinder over Silver Nut.
9. Install handle by tightening allen screw until it engages firmly with cartridge.
Changing Existing Trim:
As Above Except Old Trim Must Be Removed First. Cartridges Are Specific To Certain Trims. Even More So If Installation Is Over 3 Years Old. 3 Years Ago, Delta Went To The "Universal Rough-In" Which Made Things A Little Easier Because The Appropriate Cartidge Now Comes With The Appropriate Trim.
Posted on Sep 08, 2009
How do I take apart a Delta Monitor Shower Handle
Take a look at this link:
http://www.ehow.com/how_6155493_replace-delta-shower-valves.html
Your valve may vary somewhat but this should give you a good start.
Apr 02, 2011 | Delta & Single Handle Shower Faucet
I instslled new delta single shower faucet ,the water is running for 5 to 10 sec even if the shower handle is in off position
Sounds like someone did not remove the plastic valve assembly before soldering the valve body to the copper piping.
That or the valve body needs cleaned out. It is common for debris to get knocked lose when doing installations on old plumbing.
Jan 29, 2011 | Delta & Single Handle Shower Faucet
Delta tub valve how to replace
Depending on how old the valve is; it could just be held in by mineral deposits over time. Once the circlip is out, AND THE WATER PRESSURE IS OFF, just re-attach the handle and pull it out. The handle should give you the extra grip needed to get the assembly out.
May 09, 2010 | Delta & Single Handle Shower Faucet
I replaced my delta single handle faucet and now my water wont cut off its like my handle isnt doing anything???
Remove the handle and make sure the shower valve works the right way by itself.Make sure the handle is re installed correctly and tighten with the allen key
Apr 16, 2010 | Delta & Single Handle Shower Faucet
Shower faucet does not switch to hot.
This has happened to me in the past and had exactly the same symptoms but with a different valve. Before trying the below, it may make sense to be 100% sure that hot water is definitely getting to the valve .. can you get access to touch the hot feed pipe to make sure that it is in fact the valve at fault.
The following could be the issue:
1. The shower valve has a bit of dirt or gunk in it and is unable to allow the hot water through. It can happen with a very small amnount of dirt and is a real pain as it requires disassemble of the entire valve assembly.
2. The valve has failed and needs to be replaced - This was the solution to mine and was also significant in terms of effort.
Hope this helps, if so please leave feedback, if not let me know and I'll try and help some more!
Feb 02, 2010 | Delta T13420 Chrome Classic Single Handle...
How do you remove cartridge from 1400 series delta shower valve
Take off the handle and the cover piece. There is a large nut holding the cartridge in. Be careful taking it off so you do not twist the cartridge socket off the rest of the valve.
Oct 27, 2009 | Delta & Single Handle Shower Faucet
How to install Delta T17030 Innovations Collection Single Handle Tub/Shower Trim Chrome by my self
New Install:
Sep 08, 2009 | Delta Plumbing
Plumbing Logo
66 people viewed this question
Top Delta Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
