Question about Trendware 54Mbps 802.11g Wireless AP
TEW-430APB config problem
I was in the middle of configuring the Access Pt: I changed the IP Address and applied the setting but was unable to 'locate' the IP Address once I came out.
After much ado: I decided to reset it and start over BUT it would not reset back to 192.168.1.100 i.e browser was unable to 'find' it. Now I'm stuck unable to access the default IP or the one I set it to. !! Any ideas?
  • suprspi Nov 26, 2008
    The IP address on this device was changed to DHCP. Afterwords, it will not reset back to factory defaults.
    I have tried the reset button on the back, combined with plugging/unplugging the device, as is sometimes the case.
    I'm not even sure what subnet this one is on now that it's been on DHCP. It wasn't me who set it up DHCP, and I can't contact the person who did as they've moved on to another job. Otherwise I might be able to find out what the address even *could* be.
  • Raminda Subhashana
    Raminda Subhashana May 11, 2010
    Now your IP Address is 192.168.1.100, What is your New IP Address are you sure is there no any device name or IP on your network same as your new IP or Access point name?
2 Suggested Answers
etaf
  • 779 Answers
SOURCE: how to reset the security key of my trendnet
To change your router wireless security
  • Support site here http://www.trendnet.com/products/proddetail.asp?prod=150_TEW-430APB&cat=83
  • User guide here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10853
  • Quick setup here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10856
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - Enter IP address http://192.168.1.100 to the address location. When there is a screen needs to enter the User name and Password, both of the default Username and Password is “admin”
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password. See Page 12 of the User Manual
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --
Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Posted on Apr 13, 2010
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
I have instaled the TRENDnet tew-430apb, but, if i connect my laptop to the AP, i get connected but no internet access
Hi i have a problem with my router. Its only allowing one user to connect to it. It never behaved liked that when i bought it, so all of a sudden its behaving like that now and its really frustrating because i have more than one user in my household. Could some one help me solve this problem. I have a TEW-430APB C1 trendnet router.
http://www.squidoo.com/******-actives2
http://www.squidoo.com/waterproof-sealant
http://www.squidoo.com/apple-care-protection-plan
http://www.squidoo.com/smart-phones5
http://www.squidoo.com/dell-laptop-deal
Apr 08, 2011 | Trendnet TEW-430APB Wireless Access Point...
I cant get into config my dap1360 by typein in the dlinkap or 192.168.0.50
just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password : <blank>
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
Mar 24, 2011 | D-Link DAP1360 IEEE 80211n (draft)...
Ip address
You can get your external IP address by going here:
http://www.whatismyip.com/
You can get your internal IP Address in Windows by:
1.) Click Start
2.) Click Run
3.) Type in CMD, hit ENTER
4.) Type in IPCONFIG at the command prompt, it will display all of your IP Address's.
Mar 02, 2011 | Trendnet TEW-430APB Wireless Access Point...
Cannot received mms picture
Menu - Settings - Configuration - Personal config. sett.:
MEdia Net
Account name: MEdia Net
Homepage: http://device.home
Use pref. access pt. : No
Access point settings
Proxy: Enabled
Proxy address: wireless.cingular.com
Proxy port: 80
Data bearer: Packet data
Bearer settings
Packet data acc. pt. : wap.cingular
Network type: IPv6
Authentication type: Normal
User name: wap@cingulargprs.com
My multimedia messages
Account name: My multimedia message
Server address: http://mmsc.cingular.com
Use pref. access pt.: No
Access point setttings
Proxy: Enabled
Proxy port: 8080
Bearer settings
Network type: IPv4
Menu - Messaging - Message settings - Multimedia messages - Configuration sett.
Configuration: Personal config.
Account: My multimedia message
Nov 12, 2009 | Nokia 6300 Cellular Phone
Cisco ASA 5505 Firewall
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
May 23, 2009 | Cisco ASA 5510 Anti-X Edition...
Cant connect to the AP menu TEW-430APB
clear your browser cache, close, relaunch your browser and try again
You probably cant access it because you are not authorized. If its locked on your rooftop then your ISP should configure your access and that you're not authorized.
Jan 18, 2009 | Trendware 54Mbps 802.11g Wireless AP
Configuration Utility
Can you ping the router? I mean open a dos shell, type ping -tf 192.168.1.254 - what are the results? Maybe the ping fails, because you need to have your pc set to the same subnet address, to access the router on that IP. Test ping to your own gateway address first.. That will work & show you what to expect from a working ping. You get the gateway address by opening a dos shell & typing ipconfig /all - that shows the current IP address plus the gateway address. Actually, the gatway address might be the same as the router config address, unless you have a NAT function turned on.. Anyway, if you change your IP address to 192.168.1.252 - For example, you will no longer be able to access the internet, but shud be able to enter the configuration web page of the router.. Try the router default settings first. Another thing is that some routers require a direct cable called a 'crossover' cable to connect to the router or you have to go via a hub or a switch, with standard ethernet cables.. This probably looks confusing, but if it does not help, pls post your questions here.. Rgds,
Jun 24, 2008 | MSI RG54G2 Router (MS-6848-002)
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Wireless conections
Try the http://192.168.1.1 to access the router config page (needs Ethernet cable to be connected to the Router)
If config page still does not appear, then check your Internet Explorer settings> Security Level (not set to custom) If it is, then choose RESET ALL ZONES TO DEFAULT LEVEL and then try this address again. It worked for me.
Dec 26, 2007 | Zyxel Prestige 660HW Wireless Router...
Trendware 54Mbps 802.11g Wireless AP Logo
217 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
