How to solve error code SC546 on aficio dsm 725
jaylex
  • 417 Answers
SOURCE: error SC326 on aficio 1045
Hi there below is what is states in the service manual.
326 C 2nd laser synchronization error
The 2nd laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
• Poor connection between the laser
synchronization detector board and
the LD unit.
• Laser synchronization detector board
out of position
defective
• LD unit defective
Hope this helps you.
Thanks Jason
Posted on Aug 17, 2008
  • 990 Answers
SOURCE: How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Posted on Jan 06, 2009
  • 990 Answers
SOURCE: Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
Posted on May 29, 2009
SOURCE: RICHO AFICIO 650 SHOW ERROR 890
The code 890 do not exist like 880 but, if it is 980? the problem can be in the hard disc...
Incorrect parameter sent to the HDD controller.
First try reset the software… press the point and numeral key simultaneously until automatically it is off the copier, several seconds can pass, the copier back on automatically. The software will have been loaded again.
If the problem persists it proves with another hard disk,
since the other possible solutions already are more complicated; these are:
· Software defective
· SBICU defective
Another problem that sometimes cause erratic errors in these copiers is that it has fallen develop in some sensor having caused short circuits that annul to some times some voltage of the power supply interrupting processes indispensable for software. Example “by developer in the ID sensor” the copier scanned but nothing more. Developer in the sensors of the feeding units produced a code 322 can seem incredible but it is thus.
For it would recommend a deep cleaning of the sectors of the image unit and everything what is under the development unit.
Posted on Sep 02, 2009
Ickoajnc
  • 183 Answers
SOURCE: Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Posted on Jan 22, 2010
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
C546
change the fusing unit completely and put on the machine.
if the error appears again, enter the sp mode by
1,press the yellow key say three times and enter keys 107
2,press and hold the stop/clear key for say 5 seconds .the machine will take you into the sp mode.
3,put of the machine for about aminute and put it on again .
I believe when you follow this step well ,thie problem will be solved
GOOD LUCK.
Jun 11, 2014 | Ricoh Aficio 2045e 2035e Copier...
Error code sc546
546 is an unstable fusing temperature:
-Fusing thermistor defective
-Power supply board defective
-Defective connection of fusing unit
Feb 27, 2014 | Ricoh Aficio 1035 Copier
Error code sc546
sc546 is a fuser ready temp problem.
it requires a reset procedure: enter SP mode.touch Copy SP..touch SP DIRECT then press 7807# on the keypad then execute...turn power off and then back on
Jan 29, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
How do I clear error SC546 on a Ricoh Aficio 2045
SC546 A Fusing ready temperature unstable The fusing temperature is fluctuating. Thermistor connection loose Fusing unit connector loose you have to go into service mode and reset it
Apr 27, 2010 | Ricoh Aficio 450 Copier
63 people viewed this question
jasbo
jasbo
