Panasonic 6.0 plus base problem, when I plug in the base it has power then it says "base no power" on the screen of phone, all 3 phones that we have connected to this base. I beleave the base has gone bad & we have only had it for a few months. We bought it from walmart and when I called they said to call panasonic any way can you help with either a trouble soot or replacement or panasonic's #
SOURCE: Static on Telephone Base Unit
Try powercycling the basephone and remove the battery from the cordless phone, wait for 10 sec and then reconnect the battery, after that connect the power to base phone,probably it will fix the issue.if your phone have the option to change the channel,try changing the channel to 11 or 6.try and get it fixed.
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
SOURCE: Screen gone blank
I had the same fault with the handset losing it's display, phone worked great but could not see to access internal phone directory.
To strip down the phone you need a very clean hard plastic/granite
work surface and a small philips screwdriver and a small flatblade screwdriver.
First of all remove the battery cover and the batteries, put them in safe spot on the work surface (Tip: take the top cover off an aerosol tin to use for holding the screws and small parts you remove)
Remove the front facia by gently teasing it away from the body of the phone, there are 2 plastic lugs either side of the battery compartment, ease them towad the edge of the casing to release the front facia, it should then unclip easily with your thumbnail.
Near the edge of the phone you will see 2 small screws, remove them carefully and set them aside, please note these are longer than two other screws you will encounter later in the disassembly.
Seperate the two main parts of the case from the battery compartment end of the phone and work towards the other end, there are two release points on the outside of the casing, gently insert a small driver into the recess whilst applying a small amount of lifting pressure between the two casing halves and it should spring open. (Note that the case hinges on a clip at the top edge of the phone which helps with its re-assembly later.)
Please be aware that the speaker wires are soldered to the main board and should not be disconnecetd or cut!!!
At the battery end of the phone is a small strip of white plastic tape covering two short screws, these hold the cradle charging contacts to the circuit board, remove them with the metal contacts and keep them safe.
With a little coaxing the rest of the phone should now come out of the casing. Be very carefl not to touch any of the gold contacts on the circuit board or the buttons may not work, you may gently clean these using a dry microfibre cloth. DO NOT SCRUB THEM, simply rub gently a few times.
Unclip the display holder andnote the earpice comes loose, this can be fed through the plastic holder byturning it sideways and pressing it through. DO Not damage wiring!
You should now see the tiny ribbon cable on the display itself, either side of it are a thin white plastic lug which can be slid carefully away from the edge of the display to release the cable. Remove cable gently and re-insert it back into the connector it came from, ensuring it is fully home and is perfectly aligned at right angles to the display, then carefully slide the retaining lugs back into place which will lock the cable back into place.
You can now re-assemble the phone, carefully.
It worked for me, hopefully it should for you unless the display is damaged prior to or during disassembly.
SOURCE: Panasonic base unit went dead
THROW IT AWAY. I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE HAVE BEEN COMPLETELY USELESS!
