Question about Kitchen Appliances - Others
Giday I would like to know where I can purchase oven
Giday all, have a cherry j11 that cranks and fires but won't run, have checked all basic obvious problems but still don't have a runner, can't imagine I'm the first to have this problem, anyone else?
have the fault codes read first
if the engine is around the 100,000 klm mark check for broken timing belt
indicates that the crank or cam shaft position sensor has failed or an ING fuse has blown
Apr 15, 2017 | Cars & Trucks
Where can I purchase a new door for my smeg oven. SSA91MFP1 sn 80929 1812. The glass shuttered.
Hello Corlia;
My name is Peter. I am a retired field service appliance technician in the USA.
I do not know what country you are in, so go into your computer search engine and search, "Smeg Oven Parts SSA91MFP1".
To purchase an entire oven door will be expensive. Just purchase to glass and install it yourself.
Mar 11, 2016 | Smeg Ovens
Oven door has stayed locked after self cleaning. Error code E1 F5. Can you advise
this is one of common issue with oven when control board starts malfunctioning. Try replacing your Oven Control board. if you know the Control board part number then I would recommend you to purchase one of them from Partsimple.com. Since Partsimple is more reliable, convenient, affordable for control boards. You can either purchase a new one or even a refurbished one which work same as new one..
Try once... and let me know if required any further help on this. TV parts Water Filter Washer parts Laptop Parts Replacement Parts...
Jun 27, 2015 | Whirlpool RBS305PDS Electric Single Oven
How i know if oven reach the temperature i set for baking?
best way is to purchase a hanging oven thermometer it hangs on rack edge and you can view it thru door glass , some of the new ovens beep as well when they reach there setpoint for temperature
Mar 07, 2015 | Ovens
I have a Nobel Oven Models FSE90 and i require a complete oven door 90cm, are you aware of anywhere i can purchase one ?
I also have a noble fse90 oven with a faulty bottom element and would like to know where I can purchase a new one? Any ideas would be appreciated,
cheers
Shelley
Feb 04, 2011 | Microwave Ovens
I need to know operataing procedures or the user manual for bajaj microwave oven model :2100 etc
Sir/Madam
I have purchased a new bajaj microwave oven 2100ETC from Alive star cj through tele shopping. Just after purchase this oven is not working in microwave setting. Please suggest me how to use this oven in microwave setting.
Oct 27, 2010 | Microwave Ovens
Is it possible to purchase a different color door for the current model Electrolux 30" built-in single oven and install it? For example, if you have the model that is all black and you want a door that has...
I am unsure about the window part but I know of a site that sells covers for your ovens. While their site does not have the pictures of the oven doors available yet-- all their options are available for oven doors. They can help change your black existing oven door to white. I do not believe they can help you with the window---
Check them out www.applianceart.com
Nov 08, 2009 | Electrolux 30" Built-In Single Electric...
Oven racks missing
Most appliance stores that sell accessories have generic racks you can purchase.
Sep 28, 2009 | Microwave Ovens
Kitchen Appliances - Others Logo
29 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
