Question about Refrigerators
Need Schematic diagram for Zanussi ZF56/37FF Fridge Freezer
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
  • 54 Answers
SOURCE: zanussi zk73/46ef freezer working fridge is warm
if this is an air blown cabinet defrost it for 48hrs leave the doors open then try it. hope this helps
Posted on Feb 14, 2008
Healeyman
  • 1198 Answers
SOURCE: Need a wiring diagram for a Hotpoint fridge freezer
Check Repairclinic.com, it's a good site.
Posted on Apr 27, 2009
  • 193 Answers
SOURCE: zanussi freezone fridge freezer
well asuming you already thought to turn the thermostat down, i would check to see if you have a freon leak. with the fridge running, paint the coils with soapy water untill you see bubbles. mark that spot and dry off the area around it. generously apply electronics grade solder to the area where the leak is. (be sure you don't melt the copper and unplug the fridge first) then continue untill you have checked the entire length of coil. when all ieaks have been stoped recharge with recomended freon.
Posted on Aug 17, 2009
woodchuck789
  • 4059 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
How do I run a diagnostic test on my fridge freezer?
I would check the coolant pressure is correct. You may need the services of an engineer with the correct equipment and gas bottle.
Aug 11, 2014 | Zanussi & Electrolux Fridge Freezer Handle...
Hi, I have Zanussi ZERB 8441 fridge freezer.
Either the heater or thermostat is not working ohm them out to see which one it is
Aug 10, 2013 | Zanussi Refrigerators
I have a zanussi fridge freezer model no zx56/4w. the fridge door was left open for 10 days now fridge is too warm and freezer is icing up
you need to totally defrost the fridge/freezer and start as if it were new and dry.allow 24 hours for the unit to settle to the correct temp.
please leave feed back
Sep 16, 2010 | Zanussi ZX56 / 4 Bottom Freezer...
Fan is rattling on zanussi fridge freezer how can i get at it or ny suggestions as to what the problem is
might be ice on the fan.....when its completely frozen your fridge part will stop working.
Feb 28, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Apr 13, 2008 | Zanussi ZEBF277W Bottom Freezer...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
