Question about ASUS P4SGX-MX Motherboard
Motherboard installation installed asus p4sgx-mx motherboard get green light but blank display i know all components installed are good please help!
  • Mike Peluso
    Mike Peluso May 11, 2010
    Hi mecompe,
    Is this Asus a new used board? When you attemp power on, does the CPU fan spin? Can you hear the hard disk drive spin up & cd-rom drive spin up? If you watch the front of the case do you see any led's flash, like your floppy disk drive, hard drive led (AMber in color), cd-rom drive led & green power led on at the front of the case?
    The green led on the board means standby, the board has 5volt power, thats all.
    Are you using the onboard SiS Real256 graphics card or installed an AGP graphics card, & if so what is the model type (ATI Radeon ECT)? Is the AGP card 1.5v compatible?
    What is the total wattage output? Example:(300w, 350w, 400w ECT)?
    Understand all of the questions are relevent to your issue. Answer with as much detail as possible.
    Untill than take a look over this link: http://www.hardwaresecrets.com/article/1...
    Mike
    President:
  • 2,351 Answers
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Posted on Nov 11, 2008
Asus p4sgx-mx audio driver
  • Model: P4SGX-MX
  • Size: 2.09 Mb
  • Date added: 16-Apr-2009, 07:43
  • Manufacturer: ASUS
  • Device type: Motherboard
  • Operation system: Windows XP
  • MD5: cc496c9fc693f22e1e02bccfcc0e91b9
  1. http://nodevice.in/driver/P4SGX-MX/get54804.html
  2. http://www.nodevice.com/driver/P4SGX-MX/get54804.html
  3. http://www.driversberry.com/drivers-P4SGX-MX-fGpKoZZ1US.html
Asus P4SGX-MX Audio drivers
Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3665 File size: 2 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3620 File size: 18 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3533 File size: 2 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 4.2.0.82 File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3620 File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3533 File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Check out this page for a P4SGX-MX Audio driver download. Here you may choose your Asus device driver software. Please keep in mind that you should choose a proper P4SGX-MX Audio Asus device driver. First of all you should know your operating system, vendor name and device model. If you don't know what device you have inside try out this. Try to search for your device driver using PNPid. Open Control Panel-system-hardware-device manager then double click and click details. Use this long digits and letters line to find out what device you have and driver for it. Some drivers on our website may be packed with winzip or winrar programs.
Sep 19, 2011 | ASUS P4SGX-MX Motherboard
Sir,\r\ni want 2 know the features of asus P4SGX-MX mother board.
Hi, you can download a manual here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=15&m=P4SGX-MX&os=&hashedid=n/a
Please select your operating system.
Select the manual and click on global for download.
The file needs to be unziped before you can read it.
Aug 26, 2011 | ASUS P4SGX-MX Motherboard
Hi can anyone tell me what type of RAM is used in the Asus P4SGX-MX Motherboard please. Chris.
Your motherboard has 2 (DDR) and 2 (SDRAM) slots. DDR and SDRAM memory modules cannot be used simultaneously, and the maximum capacity is 2GB of RAM. So you can put in either DDR or SDRAM modules.
http://www.memoryc.com/asus/13039_p4sgxmxmemory.html
Jan 29, 2011 | ASUS P4SGX-MX Motherboard
I lost my motherbaord CD Asus P4SGX-MX, Now I can not installing the VGA Driver. What can I do now?
Go to the follwong site and follow these steps: -
http://support.asus.com/download/download.aspx?SLanguage=en-us
1. Select Product - Mother board
2. Select Series - Socket478
3. Select Model -
P4SGX-MX and click search, it would ask you for operating system
4. Select operating system and download drivers
Hope it helps!
CreativeTECH
Nov 22, 2010 | ASUS P4SGX-MX Motherboard
I dont have a installer in my multimedia audio controller and video controllerhow can i get the installer and how to install it
Hi. Just click on this LINK to download all the drivers available for your motherboard, Select first Motherboard then Series is Socket478 then look for the exact model of your motherboard which is P4SGX-MX then choose the Operating System installed on your machine for example XP, Vista or Win 7 then download the drivers and install it on your machine. Hope this Helps
Jun 10, 2010 | ASUS P4SGX-MX Motherboard
Asus p4sgx mx motherboard
Asus has driver software for allot of operating systems. Click the link to open Asus;
You will need to pick your current operating system from the drop down menu & click the search button. Than all the drivers for the Asus P4SGX-MX mother board will be shown. Click the + sign to open listed drivers. Choose the latest not the oldest drivers.
Thank you for using Fixya!
Mike
Jun 19, 2009 | ASUS P4SGX-MX Motherboard
Display problem
HAE FRIEND MY PROBLEM IS ASUS P4SG-M NO DRIVER PLEASE HELP ME
Jun 26, 2008 | ASUS P4SGX-MX Motherboard
ASUS P4SGX-MX Motherboard Logo
202 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
