Question about Sony Cybershot DSC-T200 Digital Camera
The toucscreen isnt working
The camera seems to be fine in every aspect but when i try to look my pictures or to get to the menu or any function that requires touching the screen when i touch it, a small hand with the pencil appears on the corner with the sign "OFF" like if the toucscreen had some hold, or lock function. but i cant use it. all the buttons on the hardware works perfectly but the screen is locked
  • juanl_78 Oct 31, 2008
    how can i go to the settings if the touch screen isnt working and the settings and menu, are in the screen:S..
    thanks anyway
  • ferchomp1978 May 11, 2010
    Hi, it seems that you have the same problem I have now...Did you find a solution???
  • 849 Answers
Go to the setting and enable touch screen option
Posted on Oct 28, 2008
How do you change the stills function from 4.3 to 16.9 its really not very clear?
Hi
Having looked at the full manual - downloaded from here and savable:
http://tda.panasonic-europe-service.com/docs/2z54662404z3z38916z656ez706466z22zdf06e277f71e6367f9e09db70241478cb0ad23ae/tsn3/data/ALL/HXWA30EG/OI/902781/vqt4x32.pdf
I think you will find that you cannot actually change from 4:3 to 16:9 aspect ratio for a particular pixel sized picture. When you set the pixels for the picture you want, the aspect ratio is set automatically.
For example:
16Megapixels 4608x3456 4:3
12Megapixels 4608x2592 16:9
See page 96 of the manual mentioned above for a full table of Megapixels, size, ratio etc
Therefore changing the picture size from the simple menu changes the aspect ratio but you do not have control of the aspect ratio for each size, in other words you cannot take a 16Megapixel picture at 16:9, it has to be 4:3.
Hope this has been helpful
Cheers
Nov 14, 2014 | Panasonic HX-WA30EB-K Hx-wa30 Upright...
I have recently purchased a LG LCD TV Model 32LK330. Everything seems to work fine except all of the people look as if they had gained an additional 100 pounds. Is this distortion natural.
It is aboslutely normal. The aspect ratios on LCDs are different from the good ol' CRTs and CRT based projection tvs. As a matter of fact when I got my first LCD tv, it took me a few months to get used to it. You can try other aspect ratios though by going to Menu-> Picture->aspect ratio and try the different settings available to see if any of them works for you.
Jul 14, 2011 | LG Televison & Video
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
Hi when im trying to load `continue game` on my fifa manager 2009 it isnt working-flashing a picture of a golfer and returning to the main menu. windows then informs me the programme isnt working. other...
Maby your save game data is corrupt, you have to start a new game, why is it corrupt? could be many many reasons,
1. You shut of the game while it was saving
Or it was a bug and corrupted your save data
Aug 10, 2009 | EA Sports FIFA Soccer 2008 for Windows
Bought a 19inch LCD Insignia TV yesterday at Best Buy. Everthing works fine except the picture won't fill out the whole screen. Can't find anything in the menu to adjust this.
On you remote control or panel buttons press the menu button. Using you on screen menu, use the up and down arrows to find the Settings Function, use right arrow to enter sub-menu. Use the up and down arrows to find the aspect ratio setting. Use the right arrow to enter the sub-menu.From here you can change the picture setting to : Normal wide 1: Wide 2 : Zoom: Cinema. Once you found your preferred viewing picture, set you choice with the enter button. Then use the menu or escape buttons to close the on screen menu. I hope this helps you with your problem.
May 15, 2009 | Insignia LCDTV26 26 in. Television
Finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
Feb 20, 2009 | Fuji FinePix S700 Digital Camera
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
My tv the picture is bigger than the tv screen
it sounds like you have hit the zoom button or your aspect ratio isnt right. the aspect ratio should be set to 16:9 (if there isnt a button for aspect ratio, change it in the menu) and there should be a zoom button on your remote and just keep hitting that and it should return to normal. If neither works, post your tv brand and model and i'll try to find another answer
Oct 20, 2008 | Akai PT4298HD Rear Projection Television
Model 51f59a hd widescreen aspect settings dont take and picture too big
I called Hitachi and the solution is in your cable remote not your tv remote. Your tv has a aspect menu as does your cable remote. Based on your cable provider you should have a settings or menu button to change the zoom or aspect of your screen. I had the same problem and have Comcast as cable and this worked for me.
Apr 25, 2008 | Hitachi 51F500 51" Rear Projection...
Camera problem
Hey, i have had the same problem for over a year. My camera also wasn't briefly showing me the pictures i took right after taking the picture like it used to. Last night i found the "Quick View" function was turned off in the menu (up arrow) of the camera, so i turned it back on. Today i tried the zoom function (i haven't tried it in a year) and IT WORKED!! So i think they are linked somehow.
So try going to your menu (up arrow) then scroll down until it goes to the next page of the menu. Select "Quick View" and turn it on. Then your zoom might work. It worked for me, but i don't know if mine is an isolated incedent.
Try it and see.
Xavi
Nov 19, 2007 | Optimus DS-5080 Digital Camera
Sony Cybershot DSC-T200 Digital Camera Logo
184 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
