Question about Intel D945GTP Motherboard
Intel D945GTP monitor going into standby, cpu fan runnning full blast
Any ideas? i was putting this comp together tonight and when i plug in my monitor to my on board video card the monitor goes into standby, and when i plug it into my actual video card it does the same thing.
also, my cpu fan is running ridiculously high.
    Problem Solver:
  • 4 Answers
First Turn off your pc & allow it to cool down & try after about 30 or 40 minutes. If you get same result remove your AC plug, VGA card, Other Expansion Cards & CMOS Battery(RAM also) After 20 or 30 minutes fix your memory, CMOS battery & change cmos jumper to recovery position & power on your PC if your pc is giving any display there will be a mesage for clear all passwords & settings select that option & turn off your pc. after taht fix your all expansion card one by one.
If your problem is same remove RAM & switch on pc, If you cant hear any beep sound you must check your powersupply & mother board get assist from hardware technician or go to your hardware vendor because there will be a warranty for your motherboard model.
Posted on Oct 28, 2008
  • 149 Answers
Your cpu might be overheating..it might be defective..if you have no video output it means ur ram or your cpu is bad
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Intel D945GTP power comes for one second and suddenly off
open the tower/ ATX cabinet and then check the two small power cable pins that connects the power button on the ATX cabinet and the motherboard, remove the same from the motherboards end (make sure you note down from where you removed the 2 power pins and then using a insulated screwdriver short the power pins on the motherboard for a second until you see the power coming on let go of the pins as soon as you see the CPU fan moving if it stays on and works normally it is a faulty power switch on the ATX cabinet and then you can either replace only the power switch or get a new ATX cabinet to fix it
you can also check if motherboard stays on if you remove the RAM chip from the motherboard. if yes its a faulty Ram and replacing the same should do the trick
you can also try cleaning the dust accumalated under the CPU fan and between the heat sink as some motherboard cuts off the power depending on the temperature
also if nothing works you can try using a different power supply unit to see if that's the case,
if still no luck then its time to buy a new motherboard.
Feb 06, 2012 | Intel D945GTP Motherboard
The computer turns on but does not boot, I get 3 long beeps
i think the problem was memory try to remove and clean it using pencil eraser. and back it properly..
Nov 11, 2011 | Intel D945GTP Motherboard
From which website i can download driver(soundand vga) for intel D945GTP
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%c2%ae+945+Express+Chipset+Family+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D945GTP
Nov 05, 2010 | Intel D945GTP Motherboard
My Gateway laptop shuts off after five minutes. I
Hi there.
There is probably dust trapped in the air vents and around the CPU fan, the best way to clear it is to turn the machine off, get a can of compressed air and give short blast through the air vents.
The CPU fan is usually located under the laptop and give a couple of blasts through that too.
Once your happy that all the dust is removed you can turn the laptop on again and it should stay on for much longer.
The cooling pad won't make any difference if the issue is dust.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | Gateway 7510GX Notebook
Nothing happens when turn comp on
firstly i personaly would not use a magnetic screwdriver pc components are delecate did you use an anti static wristband? static from you can fry components. however you may have just pluged somethig in wrong can you upload photos to a web server or something so i can see whats pluged in were?
May 16, 2009 | CTX S762A 17" LCD Monitor
D945GTP comes out of standby automatically
Check out all of your power options. Also make sure that none of your keys on your keyboard are stuck or mouse buttons. If anything touches yoru keyboard or mouse, it will come out of stand by.
Nov 30, 2008 | Intel D945GTP Motherboard
Intel MB D945GTP
give it 3 hours with no P/S plugged in, it might come back up. I just read a similar post. Dies when you unplug anything "active" from mobo, like fan, drive or floppy. MOBO senses voltage difference and shuts down.
May 18, 2008 | Intel D945GTP Motherboard
Motherboard Problem
Were all these working fine together before or did you just replace something? Did you try connecting the monitor to another PC? Try the pc on another monitor which works. try unplugging the video card and plugging it back in. try without the memory, it should post and beep looking for the memory. try without the harddrive.
Apr 02, 2007 | Chaintech Slot 1 CT-6ATA2 Motherboard
Intel D945GTP Motherboard Logo
656 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
