Dell KM632 Wireless Keyboard - Computers & Internet
Can I pop off the key of an Dell KM632 keyboard to clean it?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electrotechnician.blogspot.com/
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage"
Oct 12, 2016 | Dell km632 wireless kbmouse combowarranty:...
Dell km632 wireless keyboard left alt key not working
If the issue is only 1 key,
Please try rebooting system in safemode and check if 'Alt' key works (to figure out if the issue is with OS or Hardware)
You can even try getting into BIOS and check the Key functionality.
Can try to clean or blow the dirt around the Alt Key.
If nothing works need to replace the Keyboard.
Thanks.
Feb 20, 2014 | Dell Wireless Keyboard Optical Mouse w0147
Disable inspiron 1525 keyboard
Step 1:
Dell sells technology such as computers, computer peripherals and consumer electronics to both consumers and businesses. Dell sells both wired and wireless keyboards and mice that are compatible with Dell and other computer systems. Dell wireless keyboards may encounter hardware, software or other problems under certain conditions.
Power Dell wireless keyboards transmit data to the Dell USB receiver, which in turn passes the data to the computer's operating system. The keyboard gets power from two AA batteries. As the batteries lose charge, the keyboard's transmissions can become intermittent. Replacing the old batteries with fresh ones will ensure consistent communication and resolve the power issue. b> Interference Dell wireless keyboards operate best and are least susceptible to interference when the user places them at the recommended distance from the USB receiver. The distance, specified in the keyboard's accompanying software or installation guide, varies by keyboard. Even if the user places the keyboard at the proper distance from the USB hub, metal objects between the keyboard and hub can create interference; moving objects that create the interference resolves the issue. b> Connection The Dell USB receiver that passes data from the keyboard to the computer requires proper and secure installation in a working USB port. If the receiver connects to the USB port improperly, or if the USB port to which the receiver is connected is faulty, the keyboard will not operate as expected. The user can reseat the receiver in the USB port, or connect to the receiver to a different, functioning USB port to resolve connection problems. b> Synchronization Dell wireless keyboards can broadcast at more than one frequency, just as their associated USB receivers do. If the two devices broadcast at different frequencies, they will not pass information to each other. The user can resolve this situation using the buttons labeled "Connect" on the top of the receiver and the bottom of the mouse. Pressing the buttons simultaneously triggers the synchronization process. b> System Dell wireless keyboards are compatible with most Dell systems. However, a keyboard may be incompatible with a given computer for reasons related to the computer rather than to the keyboard. To determine if this is the case, a user can connect the keyboard to a different computer. If the keyboard functions as expected with the second computer, the problem may reside in the first computer rather than in the keyboard.
Dell wireless keyboard problems
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=715E6659A4141AFAE040AE0AB7E10D59&doclang=en&cs= - Issue0_1
Feb 20, 2013 | Dell Inspiron 1525 Notebook
Dell wireless interfering with logitech wireless
hi
just go to control pannel , select bluetoth option , paur your dell device with the system you want to work and it will work fine.
Apr 18, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My dell wireless keyboard just stopped working. I
if your mouse is working. it would be the keyboard it self.. cause dell has bout wireless mouse and keyboard.. do you have warrenty on your system.. dell can replace the keyboard for free..
Dec 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless keyboard is blinking a blue light but nothing else is working
Normally Dell keyboard require a wireless uSB plug in that connects to your computer and there is usually a small button on both the keyboard and the end of the connector. Press them both. Normally preplacing batteries causes the connection to be disrupted.
Mar 14, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Computers & Internet Logo
1,393 people viewed this question
David Payne
David Payne
