Beko WM6143S time save lite flashing & will not cancell
3 Suggested Answers
danowilliams
  • 105 Answers
SOURCE: i need a manual for beko wm6143s
Go to the website www.beko.co.uk/manuals/wm6143.pdf to download your manual from the manufacturer. Hope that helps!
Posted on Jan 13, 2010
SOURCE: beko wm6152w turn machine on
try holding the start/pause button in for five seconds, hopefully it will restart
Posted on Aug 29, 2010
I need to check the filter on a beko wm6143s. Where is it?
If you cannot remove the filter cap, do not pull or twist with pliers, this will only break it.
Instead, turn of power and water, pull the entire washing machine out and then tip it backwards at approximately 45 degrees or to the point where it is balanced.
Then undo the only visible screw behind the filter cover, slide entire lower cover to the right. this will reveal three screws, undo these and rotate the filter cap and pump body anticlockwise until the lugs line up with the gaps in the front panel. disconnect the wiring plug from the top then lower the pump below the chassis of the machine.
Remove the black hose on the left hand side by gripping the hose clamp with pliers and pushing off. The offending items (two hair grips and a shirt collar bone in my case) will be visible in the body of the pump, fully withdraw the filter cap to check for other debris.
Reassembly is the reverse of disassembly.
Jan 12, 2012 | Beko Washing Machines
I need a manual for beko wm6143s
Jan 12, 2010 | Washing Machines
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Leave power on.
Apr 26, 2008 | Washing Machines
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
