Question about HP DeskJet F4280 All In One Printer InkJet
Inc cartridge no.60,it is not available,how can I get
I couldn't get,hp inc cartridge no. 60 for HP F4280 DeskJet all in one printer or alternate for same,because it is not available at any hp centre in india, or hp solution centre.how can I get.
    Sergeant:
  • 192 Answers
HiAs a quick fix, take it to any computer shop that would be able to have it refilled.
Hope this helps
Posted on Feb 23, 2012
  • 226 Answers
Try ebay or other online stores in india. There should be an old stock somewhere somehow.
SOURCE: refilling f4280
You can know it just by using pin or something like this, insertinginto a hole on the cartridge, when you pull the pin off you can noticewhat color is on the pin. You may use tissue to see what color is onthe pin :)
My Amazon Kindle Ebook Reader 's Blog
Posted on May 20, 2009
  • 489 Answers
SOURCE: F4280 printer and hp 60 cartridge
keep the cartidge in Hot Water for 30 minutes. maybe it works.
Posted on May 30, 2009
  • 54 Answers
SOURCE: ink cartridge from US incompatible with european printer
Yes that is how hp Manufactures its printers
you will not be able to use the cartridges of Different country
There is a Process called Reagionalisation after which you can use the cartriges ....
You need to get in touch with the HP TOTAL Care for the respective country and get this fixed or else you will not be able to use it
Posted on Nov 05, 2009
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Posted on Jan 28, 2010
SOURCE: How can I fix my HP Deskjet F4280 cartridge error message?
hi..i have similar problem with anjulyn80..i bought a new cartridge but still got a cartridge error in it..
Posted on Jul 22, 2010
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Can a hp 56 ink cartridge be substutited for a 60 hp black ink cartridge
No, it cannot. I tested it on an HP DeskJet F2430. The HP56
will not fit in the HP60 carrier.
Dec 04, 2012 | HP DeskJet F4280 All In One Printer InkJet
What is the cartrigenumber l used for HP deskjet F4288 all-in-one model
Found a HP Deskjet All-in-one F4280 on hp.com that uses
. HP 60 Black Ink Cartridge
. HP 60 Tri-color Ink Cartridge
Jun 28, 2012 | Office Equipment & Supplies
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
Am trying to install HP 60 ink cartridges in my wife's F4280 printer. They don't seem to easily fit. Is there a readable graphic to assist me?
You have the wrong cartridges, that model uses the 300 or 300XL cartridge http://www.internet-ink.co.uk/hp-ink-cartridges-f4280/
http://www.amazon.co.uk/Original-300-Black-Ink-Cartridge/dp/B0019TUUJW/ref=dp_cp_ob_computers_title_0
http://www.amazon.co.uk/Original-300XL-Black-Cartridge-Capacity/dp/B0019TUUME/ref=dp_cp_ob_computers_title_1
regards
Jan 27, 2011 | HP DeskJet F4280 All In One Printer InkJet
Is there any way I can use a #61 print cartridge in a HP Deskjet F4280?
No, HP CH561WA (HP61) Black InkJet Cartridge is suitable only for HP Deskjet 1050 and HP Deskjet 2050.
Dec 12, 2010 | HP DeskJet F4280 All In One Printer InkJet
May 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
I have a new HP Deskjet F4280 bought 3 weeks ago & the blank ink cartridge was empty & I refilled it in a store & placed it back but printer recognise that the cartridge is empty & it does not have a chip.
You cannot reset the ink level for the HP 60 ink cartridge. Simply ignore the ink level indicator if you refill your cartridges. It is only an estimate of the ink level anyway. See pg 72 of the user manual.
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP DeskJet F4280 All In One Printer InkJet Logo
Seeker5211
Seeker5211
