Question about Samsung LE40R74BDX 40 in. LCD Television
Want permenat solution - Samsung LE40R74BDX 40 in. LCD Television
Cant get napper release once its snapped in, is it permenatly locked in?
Hi, turn the handle to unlock, collapse the sides and then the tricky part is toward the bottom of legs finding the other piece to press to collapse them even further.
Mar 30, 2015 | Graco Pack 'n Play
Im trying to figure put a constant power supply for powering several servos.
I buy wall chargers that match needed voltage cut the cord right at the plug for whatever it was used with before and shoulder them in. Besides that but a transformer and wire into your house permenatly. Or wire the transformer to the male end of an extension cord and just plug it in. Make sure your inputs and outputs are all correct. 11_15_2013_2_57_21_pm.png
Oct 28, 2013 | Electronics - Others
Indicator fault but bulb stays on
Sounds like a malfunctioning relay
Dec 05, 2012 | 2006 Jaguar S-Type
When i go to my access connections it not letting me click on the wifi it is permenatly on other also it shows that i am connected to a wireless connection but when i try to get online it wont connect
Sounds like it is connecting to another connection that does not have internet access. Figure out which network it is connected too and disconnect it, also set it so that it does not default to that connection. Then you should be able to go through your connection and connect to the internet. Hope this helps. Please let me know if you need further assitance.
Apr 11, 2011 | IBM ThinkPad T42 Notebook
Sleep mode keeps coming on how do you switch it off permenatly
Usually you cannot turn off sleep mode. The sleep mode will not invoke as long as there is a signal going to the port.
Jan 28, 2011 | Televison & Video
On facebook, when you clear your chat history, is it permenatly deleted
yes it is permenantly deleted.. there is no solution to this my friend
if it is important not....just dont delete the history
xxx Dudeinmood xxx
Jul 29, 2009 | Facebook Computers & Internet
Hi all,
So the only thing now is the light staying on ??
Disconect the possative cable on th battery..
That should re-set everything..
Jul 08, 2009 | 2003 BMW 330
Connection to jabra sp5050
yes if you go into settings find connectivity and choose bluetooth it should say switch on or off and that will be permenat
Jul 02, 2008 | Motorola Mobility V365 Cellular Phone
Samsung LE40R74BDX 40 in. LCD Television Logo
146 people viewed this question
Henry  Thomas
Henry Thomas
