Question about Singer Sewing Machines
How dow you fix the threading for singer 1022
Lower bobbin not threading
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Maggie_B
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
My singer touch n sew model #645 is not drawing up the lower thread. How can I fix?
here is a link for a free manual, also try changing the needle, make sure the bobbin is turned counter-clockwise, even try a different bobbin. try rethreading the sewing machine, also be could be a timing problem.
http://www.singerco.com/uploads/download/794_white-645-x.pdf
Dec 13, 2014 | Singer Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
I have loaded my Singer 626 sewing machine bobbin properly, and when I try to bring the lower thread up by turning the wheel, nothing comes up. I do hold the upper thread taunt, so it can 'grab
Make sure your needle is correct for the machine and make sure it is fully inserted and undamaged.
you just hold onto the thread... you don't need to hold it taut.
Jul 28, 2012 | Singer Sewing Machines
Upper thread will not catch the bobbin thread
make sure to use every thread guide
try a new needle
make sure the bobbin is inserted correctly
if these suggestions don't help & if the machine is still under warrenty take it back & let them check it
Mar 20, 2012 | Singer Sewing Machines
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
I have borrowed my Mother's Singer Machine # 1022 to finish a project. I have never used this model before. The bobbin threads are way to loose, which dial adjusts the bobbin tension? Also, what is the...
First check if the top thread tension is too tight. Make sure that there are no burs or other damage on the needle. Next check for lint or bits of thread between the bobbin case sections. Remove the bobbin and run a small screw driver or needle between the two silver plates on the top of the bobbin case.
Check if the machine is sewing properly before trying this next step. Find the right hand screw on the side of the black bobbin case. Make sure that this set screw is tight. Turn it clockwise. Next find the left hand screw on the bobbin case. Turn the screw 1/8 turn clockwise to tighten. Test the thread tension. If the bottom thread is still loose, turn this screw another 1/8 of a turn. Test the tension again. Do not over-tighten the screw. This can damage the bobbin case. Some sewing machine parts stores do have a replacement bobbin case available. One source is http://www.sewingpartsonline.com/singer-1022-sewing-machine-parts.aspx .
The dial with 0 F 1 2 3 4 controls the stitch length. Use the 0-1 position for zig zag Satin stitch (At 0, these stitches are very close together). Position 4 will give a longer stitch for basting. See page 4 of the manual (page 8 of the PDF) listed below. In the center of this dial is the reverse button.
Most Singer manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 1022 is http://www.singerco.com/uploads/download/62d051dd5c881663ac19c0a587e679184d936b18.pdf .
I hope this helps.
Aug 22, 2017 | Singer Sewing Machines
FEW STITCHES DROP IN BOBBIN
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Mar 20, 2009 | Sewing Machines
Bobbin tension part missing
Buy a new bobbin case. It is the fastest,easiest way to fix the problem.
sewman7
Aug 28, 2008 | Singer 3116 Simple
Singer Simple.....not really!
You really should go on the Singer website and look up support and frequently asked questions. If, you cannot find your manual they have it there to download for free. I really think that you are not threading the machine right, check it with the presser foot up and the thread should feed freely, then lower the presser foot and it should not feed at all or very little. Most of the bunching of thread underneath is the fault of the top thread not the bobbin. Make sure you turn the handwheel towards you never away from you. Also, check your needle, inserted flat side away from you and, if it were me, I would use a new needle before I sewed again, This machine comes with a dvd, try watching it.
Jul 22, 2008 | Singer 3116 Simple
Sewing Machines Logo
54 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
