Question about Alpine CDA-9856 CD Player
I love loud music
But when i play the radio loud its fine but when i insert a cd and play it loud it turns off breifly ?? changed every thing speakers,battery, alterantor what could it be?
I have alpine stereo's in all my vehicles and i have had this problem. if you run a 10-14 gauge constant wire from the stereo directly to the battery the stereo will not shut down in protection mode. it is not the cd it is the stereo going into protection mode because of lack of current not voltage. i hope this helps after i did this i could play the stereo as loud as it can go until my battery died
Posted on Feb 17, 2012
  • 11,896 Answers
SORRY TO TELL YOU THIS BUT; There is a safety feature in all cd players that while playing a cd at extreme levels, it shuts off so you don't burn out the player, altenator, or speakers.
It sucks and it's weir that it only works with cd's, but that's what it is. You'll have to get an amp
Posted on Jan 16, 2009
Vw passat 2003 burned cd s wont play
Nothing you can here this was about the time when they introduced producting coding to stop people from making their own CDs ,copyright thing so buy one of them cheap radio transmitter things that plugs into the ciggy lighter and plays a SD card so put your music on this and play through a preset radio station tuned into the sender transmitter
May 26, 2013 | Cars & Trucks
Hello, my problem is when I insert a CD(mp3), the Subwoofer gets disabled and only the speakers works. However, when I use only radio, the woofer works fine, it's only when I play CDs. My receiver is new...
it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white (amplifier remote turn on) wire to turn your amplifier on.
Jan 17, 2011 | Kenwood KDC-MP335 CD Player
No volume on phone at all
the speaker is damaged due to loud music played... when playing loud sounds more power go to the speaker thus damage it... only solution is to replace the speaker. hope this helps...
Jan 28, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Text button does not work
When you insert a cd that has folders of MP3's it's suppose to display the music info., IE., artist, album,
May 28, 2009 | 2009 Toyota Camry
Loud popping and static-vol ctrl has no effect on noise
Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of their units. If you check their web site, www.bose.com, you'll find that they will repair your unit for $100 or possibly give you $200 credit towards a new model. Before you take them up on either offer, you might want to check out the new lines of HD radios. Better souind quality, MUCH lower prices than a Bose.
Bill B.
Apr 20, 2009 | Bose & Wave& Music System
I cannot insert a CD into the CD slot.
I really like these radios, by the way, and have 1 of the radios w/out CD, 2 with the CD and one of the HD radio's. I'm one of those people that needs multiple alarms to get up so I set several of them to turn on at different times in the morning and it works great!
I have had this problem twice and I've unplugged the unit then after I plug it back in I hold down the CD eject button while I turn it back on. The display then says something like "CD Reset" and it resets the CD mechanism to the beginning of the cycle. This moves the CD holder to the correct position. (I assume the problem is due to the CD positioning device stopping in the wrong place after it ejects a CD, for whatever reason)
I hope this helps. Mine did the same thing with no CD inside.
I listen to the radio a lot, and by having these in several rooms, I can listen to radio without having to have it turned up super loud when I am walking around the house. I also use this at the High School where I am a science teacher. It produces enough quality audio to fill the classrooms with music or playing podcasts of "Science Friday."
Jan 31, 2009 | Cambridge Soundworks CD-740 Clock Radio
2003 Ford Focus Blaupunkt Cd Player issue!!!!
I hav an 03 and it exhibited the same problems; on off on off nothing works. I discovered this repair 2 days ago and it works perfectly and I am one happy camper.
1. Start by pulling the main fuse for the radio (if you already haven't)
2. Re insert the fuse and turn the radio on (nevermind the on off sequence). Insert a music CD, it will take one.
3. Pull the fuse again, count to five and re insert fuse.
4. When the CD starts to play, use the menus to get down to the factory default settings and ask it to reset to factory.
5. And you are now working again. Or you should be. It basically is a processor and it operates just like your home PC whn it needs a reload. It searchs to the default drive which is the CD player.
Good Luck everyone!
Feb 07, 2008 | Car Audio & Video
VRCD500 USB ERROR 13
BIT RATE will cause this. 128kbps is good... 192kbps OK... 256 or anything else will cause a crash. Play ONLY 128k mp3's and you won't have this problem
Jan 01, 2008 | Virtual Reality VRCD500-SDU CD Player
Alpine CDA-9856 CD Player Logo
135 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
