Displaying a white line in the same area on page after page
    Sergeant:
  • 192 Answers
Hi
Does your printer have an option for cleaning ? If so, you will need to go into the printer and scanners on my computer and click on control panel..click on printer and there should be an option for maintanence... Running this should clean and align your printerHope this helpsKind regardsMichelle
Posted on Feb 23, 2012
    President:
  • 1,702 Answers
Yes do the cleaning and if that does not do it. Try soaking the cartridge in a water
ammonia solution over night this should help.
Posted on Feb 24, 2012
White lines on both faxes and copies
clean the scanner, which is the .5 inch thick piece of glass that the ppr runs over as is is scanned
Nov 19, 2013 | Brother IntelliFax-2820 Laser Fax
While using my netbook, the screen initially would fade in and out to a white screen with white lines, now fades in and out to a white screen followed by a screen with multicolored lines --this only...
It maybe that the hinges on your laptop have gone bad. The hinges house the wires that connect the video card to your display. Your problem sounds like a case of worsening hinges. Do you see looseness around the area or hear extra sounds as you're opening and closing the lid?
It could also be that your video card and / or actual LCD screen are going bad.
All of which are pricey fixes.
Hope this helped. I wouldn't buy that battery if I were you just yet.
Jul 04, 2011 | Computers & Internet
I am getting a white line on my pages that go from the top of the page to the bottom. What could cause this?
A line all the way down the page means you have something blocking the imaging module like a bit of dirt or a piece of torn paper. Look in the area where the white line is, or it also could be toner being scraped off the page near the fuser, in that case you may see a smudge next to the line.
Dec 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Gestetner DSC 232SP: I purchased this copier used and it had printing ok. My color copies are coming out horrible. they are displaying a white line in the same area on page after page. Even after I ran a...
The white line or lines are NOT caused by the fuser. A defect "line" in the fuser would cause the symtom of the print rubbing off the page but not blank lines on your copy. First we need to separate your copy quality issues. This machine uses 4 drums, 4 developer units and a transfer belt. Most copy quality issues will reside in 1 or more of these units. Lets start with a few questions. 1)Are your copy quality issues ONLY on color copies? or are the black and whites poor too? 2) Are you running copies only thru the document feeder or have you made any copies from the glass?
Are you printing on the copier from your computer?
Dec 04, 2009 | Gestetner DSc232sp Copier
My copier is making copies that have a big blank area
Hi, first if you mean length of the page, remove the ink cartridge and see if a piece of paper is stuck on the roller where the power comes onto the paper, in line with that white line on the copy.
Aug 11, 2009 | Ricoh Office Equipment & Supplies
Automatic feed gives a white line in copy or scan
Although this problem would normally show as a black line on the copy, it's quite possible that there is something white (i.e. a piece of tape or paper) stuck on the scanner where the page feed passes through. Clean this area carefully with a soft cloth.
Jun 01, 2009 | HP LaserJet 4345mfp Printer
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Display shows pink color lines in white areas of the screen
Reinstall your VGA driver and i assume, it should be fixed if not you need to think about *********** board.
thanks
Dec 27, 2008 | Lenovo ThinkPad T61 Notebook
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
96 people viewed this question
k24674
