Question about Canon CanoScan Office Equipment & Supplies
Disassemble Canon CanoScan LiDE 600F Flatbed Scanner
  • 111 Answers
SOURCE: Canon CanoScan 5000F Flatbed.
Make sure the scanner is unlocked. Lock switch is either on the bottom, or under the scanner lid near the hinges.
Posted on May 09, 2008
SOURCE: TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
I had the same problem more than 1 year ago and then found the solution (at least in my case that is) somewhere on the internet. Since I have the same problem with a new computer I searched the internet once more, but did not find the solution. However, last time I was so clever to write down the solution on the disk of my old laptop. The laptop is gone, but not the disk, so I could access it by putting it in an USB enclosure and was able to find the solution once again. Here it is:
c:WINDOWS wain_32CNQLxx (xx is the number of your scanner) should be included in the PATH environmental variable.
Now I know where to look for I found the link where I found it first:
http://www.everythingusb.com/forums/showthread.php?threadid=7337
The entry was by pallosp.
Posted on Nov 04, 2008
SOURCE: CanoScan Lide 25 scanner
Install CanoScan Lide 25 scanner via internet; lost CD installer
just want to know how can i install my scanner, i lost my cd i can't use my scanner since i bought this last july 2008. please help me to find the site to download the program of installing my scannerInstall CanoScan Lide 25 scanner via internet;
Thanks very much
Nono Setijono
Posted on Nov 08, 2008
  • 6 Answers
SOURCE: I lost the the software for my canon scanner "Canoscan LIDE 70". where could I get the software to read "OCR". Thanks
go to the canon web sight and put in the model of you scanner and down load your drivers.
Posted on Apr 25, 2009
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Posted on Jul 04, 2009
When plugged in via usb, the LIDE 600F scanner makes a high pitched buzzing noise and will not start up.
Hi
The scanner is not able to find the home position to start.
Hence open the scanner and check to make sure the scanner assy. is moving to the end and when it senses the home position it will try to move a little away from it and then return back. But if the sensor is dirty or broken it will make a loud noise like belt slipping.
Try to find the sensor on back of the Tube assy. and try to fix it.
Jul 23, 2011 | Canon CanoScan LiDE 600F Flatbed Scanner
Canoscan Lide 600F I can't scan bacause I keep getting a message about a target disc????
target disc means hard drive or other disc that the file temporary loads to. its either full or most like write protected. right click on the scanner in control panel or the scanners. select "where" to save to in the popup menus
Oct 09, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
Needs canoscan drivers
Drivers are specific to the operating system (ie drivers for Windows XP may or may not work with Vista). Click on the link below and you will be navigated to the Canon driver download page. Choose your operating system (OS) from the drop-down menu, your preferred language and you will be ready to download the drivers.
CanoScan LiDE 600F
Oct 05, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
I've lost my CD for CanoScan LiDE 60. I
Goto Canon website
Use the following link
http://www.canon.com.au/products/scanners/scanners_low_medium_volume/canoscanlide60.aspx
Find the Downloads for your scanner.
Download the driver (if you don't have it)
Download the ToolBox for Win OR Mac as the case may be)
This Toolbox contains the software which was packaged with the Scanner.
Hope this will work for you.
Cheers
lucian44
Sep 02, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
I CAN'T TURN ON MY SCANNER
Have you unlocked it with the button on the back?
Thre is no ON button. You just choose which function you want and press the button for it, or bring up the CanoScan toolbox on your screen and select it from there.
Dec 02, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Failure to open OCR documents scanned into Microsoft Word in a readable format
Have you installed OmniPage? What OS are you using? Which scanner did you have previously? Are you able to OCR a document through OmniPage?
Jul 26, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Canoscan Setup Utility CD-ROM missing
Download the driver from the Internet directly. Or make a copy of the disk on to another CD or on to a Thumbdrive and install software!
Apr 05, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Canoscan LIDE 600F negative scanning
Colour Negative.?
Have you the software set correctly.?
Nov 27, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
old marine
old marine
