General Split Air Conditioning ASH7RSCCW
Require Manual for above model
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
  • 14 Answers
SOURCE: trane split air conditioning -XIL 14 MODEL- no
shot of freon or loose signal wire between condenser and wall unit
Posted on Sep 03, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: require specifications for an Emailair split level
Capacity which normaly known as Horse Power
or RA rating
The voltage input
Ampere ratings
voltage phase ex. (single phase or three phase)
Type: Split type
since it is split type there are several classification(wall mounted, foor mounted or ceiling mounted)
Posted on Oct 31, 2009
hvac1960
  • 2133 Answers
SOURCE: I am searching for an
Download from online:
www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298.pdf
Posted on Dec 06, 2010
intower18
  • 957 Answers
SOURCE: Need an Operating Manual in
I am really sorry I tried everything I could to find a manual in an English version, however I could not find one. I tried different approach of searching it however as of this time they don't have a manual available for English yet.
I am so sorry I tried the best I could.
Posted on Aug 04, 2011
Conia split system operating manual
Not sure if this is what you are looking for. A Make and Model would be a great help in finding the information that you are looking for. So we at West Palm Beach Air Conditioning would love give you a hand.
Manuel:
https://highcongtana.files.wordpress.com/2015/10/conia-air-conditioner-manual-ca24003.pdf
Oct 16, 2015 | Heating & Cooling
Tip
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central air conditioning unit. They also are a very good alternative to window air conditioning units. I will explore the use of these units more closely and look at how they can be used effectively.
One of the many problems encountered by the professional is when they are asked to install central air conditioning in an older home that was never designed with air conditioning as even a possibility. The walls may be very thick stone. Often they have very little or no insulation. The floor structures may be rough cut lumber. The joists spacing may be random. Walls and ceilings are plaster and lathe. Basically everything is stacked against any type of ducted central air conditioning. Many log style homes also are not very easy to get any kind of ducted central air conditioning installed. The open ceilings and the bare log wall design does not allow for any kind of ducting. I'm sure there are other situations. These are the ones that I have come across most frequently.
If you have a home or building that falls into one of these categories you may want to investigate installing a ductless air conditioner. This type of air conditioner can be installed in almost any home or building. The small indoor unit can be attached to the wall with a few screws. Most of the units only require that a three inch hole be bored through the outside wall. In new installations the units can be placed on inside walls with some fore thought and planning. For installation in older homes or homes that are already built you will want to plan the units to be on the outside walls.
The outdoor condenser units can be placed up to one hundred feet away from the indoor units. One outdoor unit can be used for many indoor units. Up to four indoor units can be attached to the same outdoor condenser. Some very advanced electronics will control the operation of the condenser and compressor to supply the refrigerant to the indoor air handler units that are running at the time. With variable speed technology the compressor and the condenser fan will only run as fast as needed. This technology has become very efficient in the last few years. You do not have to give up any efficiency with these ductless split units.
Another advantage to these mini split air conditioners is that they can be controlled to run only in the rooms that you actually need air conditioning in. If you are not going to be in a room you can shut down the unit. The units also have timers that can be set to turn the air conditioning on or off at preset times. If you are not going to be home all day the air conditioning can be setback or turned off. The timer will turn on the air conditioning so that you return to a cool house. Central air conditioning is very hard to zone effectively. Also with large central air conditioning systems the outdoor compressor will be running at full capacity even though only a few rooms amy be calling for cooling. There are some central air conditioning systems that are do some staging and variable speed technology. These are not as efficient or as effective as the ductless split technology.
Ductless split heatpumps are another great idea to look at. For a few dollars more you can also very easily have heat from your air conditioning mini split. Then especially in the mild spring and fall weather you can have some very efficient heat with out starting up that big monster of a furnace or boiler in the basement. In southern climates the heatpump version of the ductless split system may provide enough heat year around.
Ductless split air conditioning is definitely something that can solve many problems for some homeowners. Add to that the many advantages of these units and you will find that they are worth every penny that you will invest into them. As with any project like this make sure that you screen your contractor. These units are not for do it yourself people. There are many things that need to be done correctly for these units to work properly and efficiently. A refrigeration license is also required to install these air conditioners.
By doing a little research and hiring the right person you will enjoy many years of trouble free service from your new ductless mini split system.
on Dec 04, 2009 | Heating & Cooling
I have lost the manual for our LG Split System R22AWN -NC 10 air con where can I download one or buy a new one
Anna, I have provided a link to the ways to contact LG, so that they can provide an Owners Manual to you. As, your particular model, does not have an online Owners Manual.
http://www.lg.com/au/air-conditioning/inverter-split/LG-R22AWN-10.jsp
Hope this helps you.
Jun 20, 2011 | Heating & Cooling
We have a split system and can not figure out how to heat different zones (ie bedrooms). Can you please help?
what kind of split system do you have is it a ductless split like shown or do you have actual duct work where you can change the dampers
Sep 18, 2010 | Sanyo Split System Air Conditioner
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
English Instruction Manual for a Toyo TA-09CHS Split Air Con Unit
I bought two TOYO split air conditioner in 2009. They are awesome, the best quality split air conditioner in Japan. I have two manual in English and I can mail you one. Please let me know how to mail it to you.
Jul 20, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Mitsubishi r410a model puya30ma manual
where can I get a manual so that my husband stops hissing at me for misplacing it?
Jun 28, 2008 | Mitsubishi Heating & Cooling
Dec 01, 2007 | Heating & Cooling
Heating & Cooling Logo
194 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
