I have an 8 in 1 jumbo universal remote a friend gave me with no instruction manual, model # ATC-2022. can u tell me how to program it please. my tv is 55inch samsung LED
  • 226 Answers
  • 1.Turn the electronic device on that you want to use with the remote.
  • 2.Point that remote at the device and press the "Code Search" button the remote. Hold that button down for a few seconds and the LED lights on the remote will turn on.
  • 3.Press the mode button on the remote for the electronic device you turned on.
  • 4.Start pressing the "On/Off" button located on the remote. Press "On/Off" once every two seconds until the electronic device powers down. This could take you several minutes because there are hundreds of different codes.
  • 5.Press "Enter" on the remote after the device turns off to save the code on the remote.
  • Posted on Feb 23, 2012
    • 4 Answers
    SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
    Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
    1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
    2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
    3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
    4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
    5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
    6 - Repeat step #4 until you have programmed each key.
    7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
    NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
    Posted on Jan 16, 2009
    • 247 Answers
    SOURCE: need a code for an emerson jumbo universal remote
    I have a List of codes for you to try if they work you can have the whole list:
    Emerson multi-brand remote codes for tv's.
    Turn on tv. Hold tv key and press two #'s for your brand. If tv turned off, setup complete. If not repeat w/different code. Anam 32,33,38 Craig 32 Daewoo 03,13,26,32,59,67,69,71,77 Daytron 03,77 Emerson 01,03,04,23,32,34,35,77,81,83,84 Fisher 05 Funai 23,32 GE 01,03,06,07,26,38,46,47,73,78,84,86,87 Hitachi 01,03,07,08,09,10,20,30,48,77,85 JC Penney 01,03,06,07,21,24,42,57,77,86 JVC 26,27,52,79 Kenwood 01 Goldstar 03,58,61,71,77 LXI 05,12,86,88 Magnavox 01,02,03,40,41,71,77,86,88 Memorex 03,12,86,88 Mitsubishi 01,03,21,23,29,31,80 NEC 01,05,13,16,21,29,38,73 Panasonic 26,33,38,88 Philco 01,02,03,21,32,38,40,41,71,77,88 Philips 01,02,03,27,43,55,77,86,88 Pioneer 01,03,15,20,22,89 Portland 03,77 Proscan 77,87 Quasar 26,38 Radio Shack 03,16,32,34,71,77 RCA 01,03,20,21,38,42,47,78,82,85,86,87 Samsung 03,54,57,60,71,74,77,86 Sanyo 05,17,18,25,28,36,39,51 Sears 03,05,12,23,24,51,57,77,86 Sharp 03,16,23,77 Signature 45 Sony 30,43,50,53,70 Sylvania 01,02,03,40,41,71,86,88 Toshiba 05,12,24,29,57 Wards 03,06,07,16,23,40,41,45,47,77,88 Zenith 45,46,56,59
    Let me know if they work for you and thank you for using fixya.com
    Tom
    Posted on Dec 18, 2008
    • 403 Answers
    SOURCE: I need instructions and codes to program jumbo remote control
    Try this, just be patient when programing it might take a couple of minutes to program.
    Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
    Automatic Programming
    With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
    1. Turn off the device with which you want to use the remote control.
    2. Press and hold the corresponding button on the remote control
    (TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
    3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
    4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
    5. When the device turns on, press OK to store the code.
    Note:
    • To exit without storing the code, press BACK.
    • T he unit will search for the next code or the previous code if you press
    CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
    6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
    Fill free to ask me questions about anything..........................
    Posted on Sep 30, 2009
    SOURCE: Innovage Jumbo Silver Remote
    The jumbo remote -is one of the best and easy univ remotes-and you cant lose it-lol-
    go to the web site -its so simple
    Posted on Oct 19, 2007
    pidatoo
    • 118 Answers
    SOURCE: need programming codes for Innovage Jumbo Remote
    here is your manual. good luck.
    http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
    Posted on Jul 25, 2009
    Would you please help me program a large 8 in 1 Jumbo universal remote, model # ATC - 2022? I would like it to work with my small, older RCA TV?
    Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
    http://remotesearch.blogspot.com/
    http://electrohelponline.blogspot.com/
    Oct 07, 2014 | Televison & Video
    Need codes for this jumbo remote..
    This PDF is the correct manual (with codes) for your jumbo remote.
    Have a great day!
    Sincerely, CBR2009
    Jul 13, 2009 | Innovage Televison & Video
    I need instruction on how to program my JVC tv with an innovage jumbo universal remote
    Download your innovage jumbo universal remote manual here and look up the codes they have for JVC TV's.
    If this was helpful please rate the solution.
    Thanks.
    Mar 07, 2009 | Televison & Video
    Codes to program Innovage Products Jumbo Universtal Remote
    Innovage Jumbo remote codes for RCA TV; 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191,194.
    Pansonic DVD; 175.
    Pansonic VCR; 021, 060, 115, 125, 138, 148, 149.
    Philips DVD; 173, 183, 198.
    Bell ExpressVu; 168, 187, 194.
    Dec 18, 2008 | Televison & Video
    I need instructions for a jumbo universal remote
    im going to tell you automatic searching to operate your tv.... turn the tv on..
    push the tv button and the on off switch at same time and watch if the led is steady ,leave the buttons., push play button and wait 5 seconds til the led finishes flashing you have to do this about 20 times to be complete secure your remote control doesnt control your tv....but if the control found the code the tv turn it off push reverse button and leave it and wait two seconds to turn the tv on and that set push stop. ........test all functions on your remote control to the tv.....saludos.
    Nov 15, 2008 | Universal Remote Control Remote Control
    Universal Remote iwave
    I Have The Codes,But No instructions!! Big IWave . 0054-Philips Hitachi-0145 JVC-0053 LG- 0178 OR 1265
    Jun 09, 2008 | Hitachi 50HDA39 50 in. Plasma HDTV
    Instructions for Programming Innovage Jumbo Universal Remote
    You can download documentation for the Innovage remote here:
    http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
    Dec 31, 2007 | Televison & Video
    H have the jumbo universal remote from innovage pruducts. can you e-mail me all the codes? thanj you. jtorres663@aol.com
    Dec 15, 2007 | RCA RCU600M Remote Control
    Televison & Video Logo
    2,002 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
