Batter flat battery went flat unexpectedly, now wont charge and phone only work whenonnected to USB
  • 226 Answers
Try a different battery.
Posted on Feb 23, 2012
3 Suggested Answers
  • 14 Answers
SOURCE: Lg Viewty wont charge, wont start
try with a new battery your could have give up
Posted on May 27, 2009
  • 16 Answers
SOURCE: iPhone Smartphone: cant charge iphone in ibiza battery went flat...
Possible solutions
1. buy an adapter for your charger
2. plug it into a computer
3. provide more details than you have so far...
can't charge iphone is a vague way to explain your predicament...
can't charge or won't charge?
can't get an adapter?
don't have access to a computer?
Half solution, half clarification request...
Posted on Jun 06, 2010
NOKIA C7 WONT SWITCH ON HELP!!!!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Nokia C7 (8 GB) Smartphone
I left the ignition on and the battery went dead. now the battery wont hold a charge. i can charge overnight starts right away. ride for 30 mins. turn off and it wont restart.
Is this an acid batter? If so you may need to add water to the appropriate levels for it to hold a charge after you put it on a trickle charger. Otherwise, I would say the battery is dead and you need to replace. Good luck!
Jul 30, 2011 | Yamaha XS 400 SE Motorcycles
I have a ka08 i didnt charge and ran out of bateries now i doesnt work what do i do?
Maybe the battery cell is flat and needs to be charged for it to wake up again. But is will be difficult be charge such battery with a phone charger, except you use a desktop charger where the battery will be charged separately. But if you can't find a way to wake the batter, then I would advice you get another battery.
Take care
Dec 08, 2009 | Cell Phones
Battery wont charge anymore
HP had a recall recently on this notebooks batteries. Check this site for more information:
http://bpr.hpordercenter.com/sbpr/
May 06, 2009 | Computers & Internet
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
Oct 10, 2008 | LG Shine KE970 Cellular Phone
Nokia 7390 wont turn on or charge
hope phone has not had any water in it. try software update via usb cable and nokia pcsuite
Sep 07, 2008 | Nokia 7390 Cellular Phone
Help my phone battery is flat
well, quit ya job, throw ya phone, n call somebody who cares. wan there number?
Jul 17, 2008 | Samsung X640 Pink Color Cellular Mobile...
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
