Question about Pfaff Creative 4.0 Sewing Machnie
Non centered using the 120x120 ring on the screen it shows centered, but embroiders off center. I have tried to manualy alter but screen says not within area
  • PfaFF Master
  • 7,365 Answers
It's possible that the computer part of the machine is needing repair
Posted on Feb 24, 2012
Why are fun faces and embroidery not working?
Go to you tube and put in your info and videos will show you how.
Aug 26, 2015 | Singer Sewing Machines
What does stepping motor error mean?
take to service center. where are fuses is this a brother/
Nov 11, 2014 | Sewing Machines
What does the flashing circled E on the info display mean? and how do we get it to continue to embroider? it seems that the design is off to the right and it wants to embroider outside the initial square...
The flashing E means the design is either too big for the sewing field limit (about 3.93 x 3.93") or not centered. From the sound of your description, most likely the design is not centered. Check the design size in software and center it before transferring to the card.
Mar 31, 2011 | Husqvarna Rose
I was using an ATA PC card with adapter and did several embroidery designs. when I went back to the machine later and tried to pull up more designs to embroider all I got was a "communication error" on...
I have had the same thing on my 11000 Janome. Asked the repair guy, but did not get an answer perfectly. It could be the mother board from what I gathered, it happens very infrequently but you loose everything and have to start over again. Very frustrating if you made any alterations to the pattern-I have learned to save everything in case it happens. Then I just start over but it is at least saved.
Oct 04, 2010 | Janome Memory Craft 9500 Computerized...
Cannot embroider at all.
does the e have any numbers with it, like E11 or E13? Check to see if you need to raise your presser foot, or try resetting the machine. I know how frustrating this can be, I too am having problems with my machine.. it's a love/ hate relationship between us..lol
Dec 23, 2009 | Husqvarna Viking 1
My Janome 10000 stopped in middle of embroidering a design and the machine rebooted. it was making a bit of a whining sound as it was stitching just at the last..but now the hand wheel seems harder to...
Janmore10000 Stopped Embroidering thenstopped everything just shutting off.
If it is getting no power at all, it is probably a fuse. Thefuse is located in a little black box underneath the base of the machine, butit is NOT an easy job to take the box out, disassemble it, replace the fuse,and then reassemble the whole machine. But in your comment you mentioned that there is power tothe machine that means its not fuse problem.
It stopped embroidering in the middle of a project. the handwheel would notmove at all this means that it wasthread jam. Also check the carriage carriage if it does not move to the rightor left and gor stuck in one position or hardly moving a bit then it is out of calibration.
if your machine is outof calibration it will need to recaliberate . Something is like forcing theneedle through a thread jam would cause this. This is not an expensive repair.But a time consuming repair. Its advisable to get it done by service center,
click this linkdirectly to get the support center help
http://janome.com/index.cfm/ContactUs
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
Nov 29, 2009 | Janome Memory Craft 10000
Do I need the embroidery hoop? does it connect to the thing in the back of the machine and moves areouns?
  1. What do I need to get started at free machine embroidery?
    • A zigzag sewing machine with a drop-feed control. (In other words, you have to be able to lower the feed dogs so they don't try to feed the fabric.) It's nice if you can vary the width of your zigzag stitches too.
    • An embroidery foot or needle with embroidery spring. An embroidery foot helps by holding the fabric down against the throat plate while nevertheless being minimal - it lets you see what you're doing because it has very little surface area. You can alternatively get a needle that has a kind of spring built into it, and the spring holds the fabric in place. These can be nice in that they're even more minimal than an embroidery foot, but they're also relatively expensive and if it breaks you have to replace the whole thing instead of using an ordinary cheap needle with the special embroidery foot. If you use the needle with spring, you don't use a presser foot while you embroider.
    • An embroidery hoop. There are two primary kinds of embroidery hoops on the market. The old-fashioned kind, usually made of wood, has an outer ring and an innter ring. You loosen the outer ring, separate the rings, place the fabric over the inner ring, place the outer ring over the fabric, tighten the outer ring, and pull the fabric tight in the hoop. With the modern type hoop, you squeeze a pair of handles on the inner ring to remove it, place the fabric over the outer ring, place the inner ring (still squeezed) into place and release the handles. The more modern hoop is faster and easier. The old-fashioned hoop provides better tension on the fabric.
    • Stabilizer. This helps prevent puckering and slipping while you're embroidering. There are a variety of types out there. Some are papery and are torn away from the embroidery when you're done. Only use that on the back side of the embroidery, as it's almost impossible to get it all off. Others are also papery and also tear away but are dissolvable in cold water, leaving only a few easy-to-remove fibers in the embroidery. Your authors like this type of stabilizer. There is also a transparent plastic-like stabilizer which dissolves completely in water. Your authors have this but haven't tried it yet, but hear it's very nice. It's expensive though.
    • Fabric... of course. Make sure that your embroidery hoop fits on the piece you're going to embroider on. If the piece is to be small, you may want to embroider before cutting the piece from the fabric.
    • Thread. Contrary to popular belief, you can use ordinary polyester all-purpose thread to embroider, but it can weaken the fabric you're embroidering on. (If you do use polyester, you may want to fuse some interfacing to the back of your embroidery when you're done.) There is plenty of gorgeous 100% rayon embroidery thread available.
    • Thread for the bobbin. This won't be seen on the surface, so you can use anything you want. Trying to find a way to get rid of that day-glo orange thread you can't remember why you bought? Stick it in the bobbin when you embroider. Some embroiderers feel that it's best to use a softer thread (like 100% cotton) in the bobbin so as to reduce the possibility that the bobbin thread will break the embroidery thread, but your authors haven't had a problem with this to date.
  2. How do I prepare the machine and fabric for free machine embroidery? Drop the feed dogs and set the stitch length at zero. (If you can't set the stitch length at zero, don't panic, it's not that important.) Install the fabric in the embroidery hoop (with any stabilizer[s] you intend to use) so that the surface of the fabric is at the *bottom* of the hoop. (Note that if you're used to embroidering or cross stich by hand, this means you're putting the fabric in the hoop backwards.) When you place the hoop on the table such that the fabric surface rests on the table, the right side of the fabric should face up. Install the embroidery foot or special embroidery needle with spring on the sewing machine. If you're using the special needle, remove the presser foot. Place the embroidery hoop in the sewing area. (Some machines can't lift the presser foot enough to admit some hoops - you may have to remove the presser foot temporarily, position the hoop, and then re-install the presser foot if you're using one.) Set the sewing machine for a straight stitch. Reduce the upper tension until stitches interlock below the fabric instead of above or inside it.
  3. How do I lock the thread at the beginning and end of my embroidery so it doesn't begin to unravel? Make several stitches in place to lock the thread.
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
I'm using the Mega Single Hoop for the Viking Designer SE embroidery machine, because my design is too long for any other hoop. When I try to embroider, however, I get the message "Design outside hoop...
1. If the design came from the internet or a design package, it's possible that it's "center" has not been centered properly. To correct this you need to open the design in the Husqvarna Viking software and click on the "Center in Hoop" icon. That function redefines the center of the design so it will align properly in any hoop that it fits within. If you have 3d software, after clicking on that icon you physically have to put the black crosshair that designates the center in the design, in the very middle of the hoop and then save the design to your computer, then send it to the machine. The 4d software automatically centers the design in the hoop when you click on the icon.
If you have the software and you "combine" any designs together you must always click on the center design icon to recalculate or redefine the center position and then move the design's center to the middle of the hoop before saving the design. This way you center the designs center positoin around the needle position. Meaning that when you hit the start button on the machine, where ever the needle is, is where the center of your design is.
I hope this helps
Oct 15, 2009 | Husqvarna Designer I
The needle constantly breaks while embroidering. I tried every type of needle with no difference. It goes ok for a few seconds till the needle goes down and hits the foot and breaks. I do have on the...
Sounds like your tension is too tight and the thread is pulling your needle. Also, make your that you needle position button is on center. If it is on left or right it will cause your needle to snap.
Apr 19, 2009 | Singer CE-200 Quantum Futura Computerized...
Pfaff Creative 4.0 Sewing Machnie Logo
50 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
