Question about Dell XPS 15z Computer Intel Core i72620M processor 270 GHz with Turbo Boost 20 up to 34 PC Notebook
Dell XPS 15z grinding noise
I just got my Dell XPS 15z and notice that the fan comes on about every minute and a half, which isn't a problem, but when the fan slows to a stop, there's a soft grinding-type noise as the fan comes to a stop. Do I need to call Dell Customer Service about this? Or is this normal for this model, and does it indicate an upcoming problem?
  • 1 more comment
  • Mauro Bertagnolli Feb 28, 2012
    I have the same problem, does it work properly your computer now?
  • Janine Mar 27, 2012
    I got the EXACT same problem with two XPS 15z ordered couple of days ago !!!
    Did Dell find a solution for this problem?
  • okovalyov
    okovalyov Mar 29, 2012
    I have the same problem. I called support and they had a tech come by to replace the fan. It went away for a while, but then came back. =(
  • 3940 Answers
SOURCE: I have a Dell XPS M170 laptop. During a
Here is a good starting point
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Posted on Mar 15, 2010
  • 1082 Answers
SOURCE: Dell XPS M-140 Bios Locked,
Find the bios battery, remove it or otherwise disconnect it. it will be a smal lithum cell or stack of cells. Leave off for 10 -20 mins. Should clear bios ram.
Posted on Jan 18, 2011
skipper86
  • 153 Answers
SOURCE: loads slow and runs slow
Apply the following fixes to get rid of the problem:
Disable Startup programs and services
Scan and remove viruses from your computer using MSE
Scan and repair Windows registry using Reginout
Best of Luck
Posted on Sep 09, 2011
SOURCE: I can't shutdown my computer
i have the same problem
Posted on Sep 24, 2011
Geekman
  • 32281 Answers
SOURCE: how to eject a cd in a dell XPS m1330 when the hardis has crashed and the disk inside isn't a operatindg system disc
Straighten a paper clip and insert it into a tiny hole below the CD drive tray. Push the paper clip gently into this hole and the CD tray will pop out slightly. Pull the tray out to the fully opened position so you can remove the disc.
Posted on Dec 28, 2011
How to replace a noisy fan?
It would have been useful to have disclosed the model, however, this should give you an idea.
How To Tutorial Dell XPS 15z L511z Cooling Fan Replacement
Jan 20, 2016 | Dell XPS Computers & Internet
I have a xps 15 laptop when i start the laptop the laptop or window run sloe
Please do a full scan of antivirus and anti malware, if you don't have one you can get free from the internet like Avira and AVG free version. It would also help to make sure all your drivers are updated. You can try using RadarSync software to view all drivers that can be updated from your computer.
Nov 14, 2012 | Dell XPS 15z Computer Intel Core i52410M...
Dell xps beep hard drive not found
The hard drive may be malfunctioning, remove hardware and reseat back in place, if no change have it checked for possible replacement.
Oct 26, 2012 | Dell XPS 15z Computer Intel Core i72620M...
Xps 420 air temperature sensor
I would remove your fan & heat sink to check that your thermal paste isn't dry first.
Jul 15, 2012 | Dell XPS 420 PC Desktop
Dell xps 420 noisy fan black screen
more than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
Jul 03, 2012 | Dell XPS 420 PC Desktop
How do I remove a CD from my computer?
There should be a pin hole on the cd door that you can insert a paperclip into, and that will release the door...
Jun 08, 2012 | Dell Xps 15Z (fypuhxb8) PC Notebook
I hear a higher pitched solenoid buzzing for about 10 seconds every 30 minutes or so. It is a new sound and it seems to be coming from the lower right side of the fridge but I don't notice any...
is your ice maker hooked up?if no water is going to the ice maker and the arm is down it will buzz.also check the fans one in the freezer and one in the rear for the compressor and condenser,maybe a piece of paper is hitting the fan blade when the fan starts or it could be vibration in the frame,ytou can remove the bottom kickplate and you say every half hour or so it makes the sound and listen to see if you can pinpoint the noise,when you open the freezer door the evap fan will run,you can check that fan motor like that.you have to do a little detective work to find the noise but if the ice maker isn't hooked up to the water source and the arm is down it will buzz.good luck.
Jun 06, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
It's making an extremely loud noise it may be the fan but i'm not sure :)
Good day. What you can do too resolve this issue is to clean your fan from dust.. Usually the fan sucks in dirt while keeping your system cool, overtime this dust clogs your fan causing a loud noise. You can also check your hard drive because defective or hard drives that have problem causes scratching noise as well. Hope this information help you a bit. Have a great day.
May 29, 2011 | Dell XPS 200 PC Desktop
Loud grinding noise. Paper only coming half way out then getting Jam notice. Loud grinding is very loud.
Hi
Grinding noises indicate either gears that are self destructing or something is stuck inside. Take out the cartridge(s), remove the paper and all the plastic that comes off. Unplug the cables. Now lift the printer, turn upside down and shake. If there are broken gears a local repair shop might try to fix it but most stores refrain from this.
Aug 05, 2009 | Dell 1600n All-In-One Laser Printer
Dell XPS 15z Computer Intel Core i72620M processor 270 GHz with Turbo Boost 20 up to 34 PC Notebook Logo
611 people viewed this question
Alun Cox
