Question about Coffee Makers & Espresso Machines
Coffe machine problem
This machine is not ejecting spends grounds properly in hard cakes they are coming out sloppy and messy inside machine
  • Joseph CARFI Feb 23, 2012
    Hi it is a delonghi magnifica automatic coffe machine eam 3500 thanks
  • Joseph CARFI Feb 25, 2012
    It was a bit helpful but the spends cakes are still a bit wet machine is a eam 3500 delonghi magnifica fully automatic coffee machine
4 Suggested Answers
  • 1089 Answers
SOURCE: Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Posted on Jun 17, 2009
  • 109 Answers
SOURCE: The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Posted on Feb 22, 2010
SOURCE: hello, the spent coffe holder fill up with water
water fills spent coffee holder during coffee making
Posted on May 16, 2010
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
The flow of coffee is really slow
try to large the granulates the cofee ground. inside the coffe tank is the numbering disc. try to put him exemple: is at 5 put it to 7 and make 3 coffe then the flow of coffe will go faster
Sep 29, 2014 | Saeco Spidem Villa Espresso Machine
XP7240 not draining properly
Replace that pressure valve and also inspect it for leaks from directly under the boiler, from that pressure valve and from the top of the hydraulic ram. If when you buy your valve you find the white housing will not fit where the old one came from you can just use the piston into your old housing. Check this before removing the hose clip from your old piston housing. If your old piston housing is leaking badly before you even do this job then you will need to replace the whole distributor as sometimes a piston housing retaining lug can fracture, there are 3 of them and they are part of the distributor.
Jan 26, 2014 | Krups Small Appliances Espresso Machine
Coffe does not come out. It grinds but wont drip out.
Hi...The grinder is set too fine, first check the ground cake ,it should be grainy form not in powdery form. Set the grinder about 2 notches coarser.It should fix your problem.
Sep 03, 2010 | Saeco Talea Giro Espresso Machine
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Bottom thread is so sloppy
Are you sure the machine is threaded properly? Try tightening the tension. And make sure the bobbin was wound in the correct direction.
Aug 01, 2009 | Kenmore 12102
Hi
Jun 17, 2009 | Gaggia Titanium Espresso Machine
Grinder starts, but doesn't wet coffe before red light comes on
This is a duplicate, here's the answer
I have the same problem but it's easy to fix. Turn the machine off. Open the front panel. Remove the dump box on the side. Pull the grinder unit out.
Look at the thing you just pulled out. You'll see a little ramp going from where everything slides down from the top. That ramp gets damp and the freshly ground coffee starts sticking on it. Take your finger and wipe it off.
Next, is kinda hard to describe. If you put your fingers inside, along the top, center edge of the machine you'll feel a ridge. It's a spring loaded door. Pull it down and clean the grounds out.
Slap it back together and you're good to go. Only takes about a minute when you get the hang of it.
Jan 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
47 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
