Question about Zyxel NBG-419N Router
Open telnet on zyxel419 and set static arp. WOL on Wan only works acouple of minutes and I would like to set static arp in router
When i open my internet it scroll very slow so i open my LAN connection using Realtek RTL8168D(P)/8111D(P)PCI-EGigabit Ethernet NIC and open its'properties and click the box repair and suddenly a...
Hi
The Address Resolution Protocol (ARP) is very crucial for TCP/IP network communication. If you begin to notice network connectivity problems such as particular web pages not loading or not being able to ping certain IP addresses then clearing your ARP cache is a good place to start.The TCP/IP ARP Command component provides the functionality to add, delete, or display the IP address for Media Access Control (MAC) address translation.
To flush/Delete the ARP cache in windows 7/Vista/XP/2000/Server 2003/2008 follow this procedure
Click on Start->Run-> type the following command click ok
netsh interface ip delete arpcache
Dynamic ARP cache entries update persist for 2-20 minutes depending on the system.
Windows 2003 Server = 10 minutes
Windows 2000 professional/Server = 10 minutes
Windows XP = 2 minutes
Solaris = 5 minutes
Delete IP address using arp command
arp -d <ip address>
Example
arp -d 10.1.1.2
Display arp table
arp -a
Add static entry to ARP table
arp -s <ip address> <mac address>
Example
arp -s 157.55.85.212 00-aa-00-62-c6-09
Jun 21, 2011 | Nvidia Computers & Internet
Tip
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 | Computers & Internet
Tip
HOW TO CONFIGURE STATIC ROUTING ON LINKSYS ROUTER
STATIC ROUTING:
1STENTRY 1ST ENTRY
SM: 24 SM: 24
2NDENTRY 2ND ENTRY
SM: 24 SM: 24
1STENTRY
SM: 24 SM: 24
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
Use Static Routing
Select Entry
Hop Count = 1 + n
on Jan 26, 2010 | Linksys Wireless-G WRT54G Router
If I unplug the internet wire from the netgear and plug into the modem the internet works the minute I plug back into the netgear the internet does not work any suggestions
Most likely your router is not configured correctly. you did not indicate which ISP you have but since you can get on line when connected directly to the modem I would assume that one of two things is happening:
your ISP provided a static IP which is in your computer and the the modem is configured as a bridge.
- this option is very unlikely as most IPs are assigned dynamically.
option two your modem is configured as a router and is getting its information assigned dynamically from the ISP. In this case you will need to log into the web interface of your router (typically 192.168.0.1 if not try 192.168.1.1) with login of admin and password for the password.
make sure the WAN interface (Internet interface) is configured for automatic configuration (DHCP)
save the settings in the router.
reconnect the modem to the router and power off the modem first and then the router.
power cycling the modem and router will clear out the arp cache in the modem.
after they power back up you should be able to go back in to the router and verify that the router has obtained an IP from the modem.
Jan 04, 2011 | NetGear RangeMax WPN824 Wireless Router...
I have a problem with Wake On LAN (WOL) on my PC. I have a GA-G41M-ES2L (revision 1.0) motherboard. a) Upgraded my BIOS to v8 (Yes, v6 fixed an issue with WOL, which I upgraded to at the time, and now...
My only suggestion would be to go into Windows power options on control panel and see what it's set to do at shutdown.If it goes into hibernation,it will dump everything in RAM,which includes your WOL process.Try setting it to sleep instead and set the put computer to sleep time where you want.
Also,there's a link to "choose what the power button does",set that to sleep as well.
Good or bad,please rate my post?
Thanks
Bob
Aug 11, 2010 | Gigabyte GA-G41M-ES2L Motherboard
I am trying to telnet through a Linksys RVS4000 from the wan side of the router to a fixed device on the lan side of the router. Both networks wan & lan are operational and I can ping the Wan side...
run netstat on the lan pc to see if telnet server is listening on port 23. look at logs on the router and pc to see if it is blocking any traffic. make sure lan pc has route back to wan
May 14, 2009 | Computers & Internet
Cannot find print server at all
How this works: Restoring the PocketPrintServer to Factory Defaults In most cases, the best way to restore the PocketPrintServer to factory defaults is through "telnet". However, if you are unable to connect to the device because of a configuration error, use the following method which does not require a network connection. To restore the PocketPrintServer to factory defaults, complete the following steps: 1. Disconnect the PocketPrintServer from the network and power cycle it. When it powers up, the LED will rapidly blink orange for five seconds. 2. Power down the device during the rapid orange blink period. Power up the device and power it down during that orange blink period two more times. 3. Reconnect the network cable and power up the PocketPrintServer. It will have restored itself to factory defaults and will rapidly blink green as it searches for a RARP or BOOTP server to find an IP address. Gleaning If an IP address has not been permanently assigned when the PocketPrintServer is powered on or reset, it will look for a "ping" packet on the network. If the PocketPrintServer receives a "ping" packet within two minutes, it will accept the IP address in the "ping" packet as its own address. To use Gleaning, you must have super-user privileges on a UNIX system. Gleaning also works under Windows 95 and Windows NT. 1. Add an entry in the ARP table that assigns an IP address to the Ethernet address of the PocketPrintServer. To do this, use the "arp" command. arp -s temp Example: arp -s 192.168.42.24 00:02:16:00:00:01 temp 2. Start a continuous "ping" to the PocketPrintServer. ping Example: ping 192.168.42.24 On some systems, this may require an additional parameter. Some implementations of "ping" only send out one "ping" packet which could get lost in transit. Check your system documentation for more information. 3. Connect power to the PocketPrintServer. The PocketPrintServer will "glean" its IP address from the "ping" packet. This IP address will remain in effect until the PocketPrintServer is power cycled or reset. Therefore, a permanent IP address should be assigned by running the ExtendView TCP/IP utility or via "telnet".
Jan 30, 2007 | Extended Systems Pocket Print Server
Finding the Dynamic Address Assigned by the ISP on a RT311 or RT314 Router
Here are three ways to find this information: 1. Within the browser interface of the Router, enter Maintenance and the WAN PORT is your dynamic address assigned by your ISP. 2. Enter the telnet interface (start-run-telnet 192.168.0.1-and enter password when prompted) of your Router and enter menu 24.1 (System Maintenance-Status) and the dynamic address is listed as the WAN IP address. 3. Enter the Serial Manager (except the RP114) of the Router and enter menu 24.1 (System Maintenance-Status) and the dynamic address is listed as the WAN IP address.
Feb 19, 2006 | NetGear (RP114NA) Router
Feb 19, 2006 | NetGear RT311 Router
Feb 19, 2006 | NetGear RP114 Router
Zyxel NBG-419N Router Logo
167 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
