Question about Hitachi HTS543232A7A384 320 GB SATA II Hard Drive
Hitachi HTS543232A7A384 SATA clicking sound
I bought my ASUS 1215B close to a month ago and almost from the start the hard drive has been making a clicking noice both in idle and when I am working with the laptop. It is not a "click of death" it sounds more like the reading head/arm moving back and forth or something like that. I'm sorry I cant give a better explanation but I dont have a great knowledge in hardware. The clicking sound is driving me crazy and really demotivates me to work with the laptop at all... Please does anyone have any suggestions?
    Master:
  • 451 Answers
If it is clicking then the hard drive is slowly beginning to degrade. I would contact the manufacture ASAP and get it replaced.
Posted on Feb 24, 2012
Getting system to recognize Hitachi CinemaStar P7K500
If you have OC that motherboard, roll it back. The drives that you are using are dinosaurs compared to the motherboard. Legacy issues exist.
Mar 03, 2017 | Hitachi CinemaStar 7K500 HCS725032VLA380...
Hitachi Deskstar causes a Power Error on my Gigabyte GA-Z68AP-D3
test all leads that attach to your hard drive including electrical extensions, SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
make sure the CPU central processing unit has thermal grease and a dust free secure seating
even something as small as an electrical extension or a faulty fan lead can cause this problem computers need all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
could be a memory dump you might have to many programs running at one time putting to much stress on the CPU not having enough ram will do this
might be getting to hot make sure the CPU has a dust free secure seating and has THERMAL paste
if you right click in the bottom toolbar select task manager applications you will see whats running also processes you will see whats ticking over if you see something running that should not be select end now you might even uninstall that program and some unnecessary programs
check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
some motherboards cmos batteries are soldered in
hope it helps
May 08, 2012 | Hitachi Deskstar 35 1TB 7200RPM SATA II...
I set a password on my hard drive and i lost it i need help
The only thing I can suggest is www.ebay.com Type: hdd password that will bring up a list of sellers that you can choose from, also! www.download.com might be worth a look at.
Apr 02, 2012 | Hitachi HTS543232A7A384 320 GB SATA II...
When starting the laptop, it says "operating system not found", the hard drive (hitachi hts541612j9sa00) makes a sound like trying to run but not being able to do so. I tried to take it out an...
Hi
Thank you for using FIXYA!!!
Before we start thinking about trashing the drive, we can ask some questions, and if the results are negative, it is most likely a spindle failure in the drive itself. Basically this means that the repair cost will be much more than just to replace the drive.
I have written a tip which will be able to diagnose the problem. To navigate to the tip, you will need to click on the link below.
Click HERE.
Just to clarify: The clicking noise i am referring to in the tip does not necaserilly need to be loud, if the drive makes a different sound that it use to make, it is most probably done.
Please do not hesitate to let me know if you have any further questions.
Kind regards
Lock123
May 20, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Hi, I have problem here. I just bought Hitachi Deskstar 7K1000.C. It works fine at first, but one day latter some clicking noise appear. It detected in BIOS, but then make my Windows take a very long time...
The short answer is the drive is having trouble calibrating itself, and should be sent back under warranty for replacement.
There are things you could try to recover the unit, but why risk voiding the warranty only to wind up with a questionable drive afterward?
Mar 17, 2011 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
I bought a Hitachi z5k320 hard drive trying to install it, and windows, but my computer won't recognize hard drive. how can i get it to recognize the new drive. can't do anything until that happens.
As long as you are sure the hard drive is connected properly with SATA cables to the motherboard and has power from the power supply unit, and that the drive is working, you can enter the BIOS on computer startup and modify the "boot device" look in "primary boot device" for a name matching that of your hard drive (probably "HITACHI .....) If it is there select it as the primary device and hopefully it will boot and ask you to install windows. If it is not there the drive may not be connected or it may need to be replaced. Hope this helps!
Mar 15, 2011 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
Computer doesn't detect drive
Hello
I had this problem a few months ago and i fixed it by following this steps.
Go to control panel.
Administrative tools.
Computer managment.
Storage.
Disc management.
Right click on you drive in the chart
Click on change drive letter
Change
Restart your computer and it should work.
Please rate this.
Best regards
Sep 25, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Gets stuck on the "asus" screen when i trun my laptop on.
Could be that the hard drive is not making a good connection. Turn the laptop upside down. Find the "latch" where the hard drive is "housed" and remove the drive... Then carefully and firmly replace it and make sure it makes good contact. Then try again to boot the laptop. If it still does not start up TAKE IT BACK to where you bought it from and let them sort it out 'cause it is supposed to be under warranty for at least 1 year
Aug 03, 2009 | ASUS Eee 4G Notebook
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Hitachi 500 GB sata Hard Drive
i have just format my compter now im haveing problums geting my sata hard drive back in i have the floppy disc what came whith it not shore how to install it
Jun 13, 2008 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Hitachi HTS543232A7A384 320 GB SATA II Hard Drive Logo
497 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
