Question about Canon EOS 40D Digital Camera
Dead camera With full battery and the camera is not working. Totally dead when I turn it on.what can be the problem?
I have had this problem once (on my first paying job)
Remove the battery and clean the contacts ,
Then check the contacts in the battery compartment they will needed cleaned to
Hope this works for you
Posted on Oct 30, 2008
I have a Nikon Coolpix L22. I was taking a picture and all of a sudden I got a lens error message. now, yhe camera is totally dead.
If the camera will not turn on, you probably have a bad battery. Replace the battery with a new one and try again. It is possible that the battery was almost dead when the lens tried to adjust and this may have caused the lens error message before the battery completely died out. Else you will need to send the camera in for repairs.
Aug 03, 2011 | Cameras
When I turn on camera, get message "change the battery pack" and then camera turns off. Also, where I can get an instruction manual -- I must have lost mine. Thanks,
Rechargeable batteries don't last forever. Lithium batteries in particular can fail early if they are allowed to become totally discharged.
The best way to proceed is to buy a new battery, then try to charge it. If it charges and the camera works, problem solved. If it doesn't work, then the problem is something else (dead charger?). The battery will not be wasted though, as it is always handy to have a spare.
You can download a manual from this page.
Nov 05, 2010 | Canon PowerShot SD1100 IS Digital Camera
I checked the TTL flash contact at the right side of the X700 hot shoe, but no TTL flash control, instead the flash unit gave a full burst.
This could be several things. From loose/dirty cable connectors to circuit board issues. It could totally be just the age of the batteries and capacitor in the flash taking a long time to charge, making it look like it took full power. Put in new batteries or take out the old ones, rub the contacts on your jeans, and put them back in.
When you quit laughing, this actually works. It removes that thin patina that develops on the battery terminals over time.
It's also possible that the flash sensor is dead, but that's the least likely item.
Apr 25, 2010 | Minolta X-700 35mm SLR Camera
My polaroid is dead but theres a full pack inside. Is there any way to charge it up with out buying new film?
In short, no. It's not a rechargeable battery.
You can't solve the problem with a new photo pack either as they're all long out of date and out of production and so most remaining ones also have flat batteries. Those which aren't totally dead typically die completely after ejecting the protective cover sheet.
The only fix is to modify the camera to accept an external 6v power supply, but it's not that easy as the camera casing clips together and was never designed to come apart and so often the casing breaks during the modification attempt. But given that most charity shops either have a back room full of unsold (unsellable) Polaroid cameras and that they're easily obtained via FreeCycle and Freegle it's not really an issue if it takes five or six attempts to end up with one modified camera.
The supplies of photo packs are a different issue though: they're very expensive, don't usually work unless on a modified camera and are increasingly difficult to obtain as supplies continue to dry up.
Apr 21, 2010 | Polaroid OneStep Express Instant Camera
The camera is dead, doen't turn on, and the batteries are new.Help!!
1)Try a full reset of the camera by removing the batteries for 24 hours. It's possible that the battery monitor circuit is stuck on the wrong value. Often with electrons, by removing all power from it for a day, it drains it if any backup memory it might have and will reset. (Kind of like how if you pull the plug out of your TV for 5 minutes and then plug it in it's fine, but pull it out for a few days any you may have to totally reprogram the channels on the TV)
or
2) Some cameras just don't do well with regular alkaline batteries. And the older your camera gets, maybe the more it's eating up power. You could try rechargable lithiums, you may find they will work better.
Jan 10, 2010 | Canon PowerShot A460 Digital Camera
I also have Casio Exilim EXZ75 I didn't charged it for almost 3 weeks and once I charged it, the red light flashes on and off... Then I inserted it in the camera... it still doesn't work... how can I solve...
kindly leave the battery for long duration in charging position let the red light blink and then see after like 16 hours or 24 hours if it works and charge otherwise change the battery with the same specs , and next time when u leave battery for long duration likea month or weeks charge it to full or half so it can hold some power to re charge again , ur battery is in Coma state nearly dead so it might come back or not
pls rate me well
Regards
Zohail
Aug 11, 2009 | Casio Cameras
Wont turn on
Well to be3 a 100% about the battery I would replace it with one that you know or is guaranteed to work. Camera batteries can look OK from outside and be completely collapsed inside.
No Charge lights can indicate NO battery and if there is one inside then it is dead and registers as a no battery ( no charge light)
The red light blinks in very low state, but totally discharged it will not blink and wont blink again until loeft on chareger for about 3-4 hrs to overcome the low state.
Jul 25, 2009 | Kodak Easyshare M753 Slim Digital Camera
I pod nano
my 4gb ipod nano wont turn on with full battery
Aug 22, 2008 | Apple iPod nano 3rd Generation
Battery fully charged but cannot use camera. Applied new batteries works in review mode only Fuji Fine Piix F420
My camera had a similar problem. It would work only in review mode and as soon as photo/film mode was selected it went dead. What I did was 'discharge' the battery totally and then fully recharged it. This can be done by going to Menu-Option-Setup-Discharge. After I had done this the camera stopped going dead but the battery still had a very poor lifespan. I bought a new battery and now the camera works as new. Hope this helps-Steve.
Aug 16, 2008 | Fuji Cameras
Canon EOS 40D Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
