Question about Toshiba Satellite M35X-S349 Notebook
Screen compressed, can not establish 1280x800 resolution
Hi, display problem. Even when I'm at the BIOS screen, the widescreen display looks like it's compressed to normal width at the left side of the screen. There's a black bar down the right 20% or so of the screen, but a strip of the display seems to be aliased onto it. thanks for helping.
Hi! If this is still a problem until today, I know how to help you, just send me a e-mail at mrc23_99@yahoo.com. Regards
Posted on Apr 06, 2007
Netflix will not play when connected to my avtex L188DRS only get sound
The avtex L188DRS is a widescreen display with an aspect ratio of 16:10. Netflix plays HD not Widescreen, so you will have to check your monitor to see if you can select a 16:9 option or look for settings on the device you are using to watch Netflix and see of there are 16:10 options.
16:9 resolutions
1280x720-----16:9
1365x768-----16:9
1600x900-----16:9
1920x1080-----16:9
16:10 resolutions:
1280x800-----16:10
1440x900-----16:10
1680x1050-----16:10
1920x1200-----16:10
2560x1600-----16:10
3840x2400-----16:10
7680x4800-----16:10
Oct 23, 2017 | Computers & Internet
Sis m672mx
it has on-board graphics,15.4 Widescreen, Screen Type - WXGA ,Screen Resolution 1280 x 800 is default.....
Mar 05, 2014 | Canonical Ltd. Computers & Internet
Screen flashed and stopped displaying widescreen
Usually this is because the display has been changed from 16:9 (widescreen) mode to 4:3 (standard) mode. On the front panel there's a button labelled "4:3 in Wide." Press this button to return to Widescreen mode. If it says "OSD Locked" then you need to hold the "Menu" key for several seconds to unlock the controls, before changing it to widescreen.
If that doesn't correct the problem then you need to adjust your computer's output resolution to a 16:9 ratio like 1920x1080 (1080p) or 1280x720 (720p.)
Oct 22, 2012 | LG W1934S-BN 19" Monitor
My screen is wide and not formatted correctly. What do I need to adjust to go back to a full screen mode?
You need to find out the native resolution of your monitor, then adjust the PC video resolution to that required by your monitor. Brand and model?
Feb 22, 2010 | Computers & Internet
Laptop wallpaper problem
Reinstall again your Automatic Wallpaper change. This might be the problem is your wallpaper changer, check the setting if it is TILE, CENTER or STRETCH, only this 3 options are available on wallpaper, aside from resolution if only for viewing purposes.
Jul 29, 2009 | Dell Inspiron 1420 Notebook
Black bars
You should right click on your desktop (in the blank space, not on any icon or object) and select the Properties option. This will open your Display properties (but you knew this already). Go to the Settings tab at the end, and see if you can slide the resolution bar to 1280x800. This is the native resolution for your laptop's screen. If you select 800x600, you're widescreen laptop is attempting to display a 4:3 aspect ratio, so it cuts off what it doesn't need. If you select a widescreen resolution, it should automatically adjust so that it takes up the whole screen. If you don't have the option to go any higher than 800x600, you're laptop is missing the correct video drivers and you'll need to reinstall them. You can get the video drivers for your laptop here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1300/B130&os=WW1&osl=en&catid=&impid=
May 13, 2009 | Dell Inspiron B120 Notebook
New Hard Drive
Hi you can buy any 2.5" ATA harddrive .doesnt matter what make you buy them can get on Ebay, and which ever size you want,ie,80GB,100GB-
you will need a copy of windows though to install the operating system
Dec 07, 2008 | Computers & Internet
Changing Screem Res to 1024x720
Hi LSmitten,
So your brother has laptop, and you can't change the screen resolution, I will take a guess that most likely the screen resolution right now is 800x600 or 640x480 which most games won't work with. The most likely culprit why you are not able to adjust the video resolution is that he hasn't installed the video driver of the laptop yet. You should install the video card driver for your laptop in other for you to change the resolution of your desktop. I suggest that you download the latest video driver from the computer manufacturer's website.
Also if he is using a older laptop, the LCD screen on a laptop has a set maximum resolution that you can use only. Older model laptops can only go as high as 800x600 upto 1024x768. Most of the new laptop nowadays have a minimum LCD panel of 1280x800 widescreen. Check the PC manual to see the max resolution the LCD can handle.
Hope this helps!
Peace! :)
Oct 20, 2008 | Computers & Internet
Thoshiba SATELLITE A200-1Z3 Laptop
It could be that the screen is at the correct resolution, but the icons are just set to display larger (Vista allows this). Right-click on the desktop (NOT over any icons), and select "View". there you can select the size of the desktop icons.
Sep 04, 2008 | Computers & Internet
Hi i want to widen my screen
The Resolution can be changed in Windows XP by minimizing all applications, right clicking on the desktop, selecting Properties. In the Display Settings window go to the Settings tab. Here you can change the resolution. I think you are wanting to use a widescreen setup so going for a resolution of 1280x800 should fill your screen. Play around with the available settings to resize the screen.
If you are using MS Vista, you need to minimize all applications to the desktop, right click, select Personalize. In the Personalize Window click on Display Settings down the bottom, modify the resolution as appropriate.
Alternatively, you may be able to find the function key that did this to your resolution. Above your F1-F12 keys there should be a little picture. If you click on the [fn] key (near the Windows key) as well as one of the F1-F12 keys you can cause different functions to be performed. This may be how the resolution changed initially.
Good luck
Apr 23, 2008 | Toshiba Satellite A35-S159 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
