Question about Gerber Blades Home
Have a eco/flush B8100 and it wont flush
Has handel that flush1.6gup and 6lpf down
3 Suggested Answers
  • 196 Answers
SOURCE: have to hold handel when flushing
Check the linkage going from the handle to the flapper inside the tank. If it is too long, it won't lift the flapper high enough causing you to have to do it manually by holding the handle. Also check the flapper itself. They are a rubber piece that seals the output of the tank smack dab in the center of the bottom of the tank. Depending on the age of the toilet and if you have hard water, it should be replaced. It's a $5 part at Home Depot or Lowes. Most of them do not even require tools to install. The rubber just slips over a couple little ears on each side of the siphon tube.
Posted on Apr 09, 2010
  • 24 Answers
SOURCE: must hold handel down for proper flush
you need to replace the flapper inside the tank. Make sure you get the correct replacement. that
should take care of it for you.
Tool Belt Diva
Posted on Jun 12, 2011
I have a EcoFlush B8100 and it does not want to flush even if i turn the knobs.
First check the filter in the supply line ( this is where the hose from your house hooks into the tank ( inside the tube( tank side) (youll need needle nose pliers) pull out screen and flush screen with water. if that doesn't work ....change the flush cartrage with a B8106 replacment( its the thing in the middle under the tank lid that has hoses comeing out). You have a ecoflush system that is covered for 10 years from the manufactorer. call 1-800391-9821...I have 301 of these in a hotel and im the chief engineer.. good luck... there easy to change
Jan 02, 2012 | Coffee Makers & Espresso Machines
Must hold handel down for proper flush
Tool Belt Diva
Jun 11, 2011 | Eljer TITAN 15" Two-Piece Toilet - 09
I have an EcoQuantum dual flush toilet, all of a sudden it flushes sometimes & sometimes it won't flush at all. I push the handle down/up & nothing happens. Water pressure has not changed at my...
EcoQuantum B8100 is junk in my opinion. There is an obvious design flaw in the handle. The flush/no flush problem lies there. If you contact the company, you can get another handle from them, and problem will be solved. However, it WILL happen again in a year or so, and you will come full circle. Their number is 1-800-391-9821.
Nov 11, 2010 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
Water leaking inside toilrt bowl
The flush megnisems rubber has parished.
Step1. open sistern and locate the flush meganisem, [shoold 90% of time be the gajet in middel]
Step2.unhook or unscrew all the handels conected to it,
Step3. turn the meganisem left, it wil pop out and at the bottom after you pop it out u see a black rubber that looks damaged, go to plumbing shop with the rubber and they will give u 1 ,its cheeep.
that should fix it.
plz rate my advice
Jul 12, 2010 | Eljer Toilet Onepiece Canterbury ...
One of our EcoQuantum toilets really doesn't flush. It flushes part way, but only pushing the handle down; it does nothing pushing the handle up. We have to flush several times to get it to work. What do...
Hello
Im Rossouw. qwalifide plumber
Ur problem most likely is ur arm conected to your flush handel.
If the arm is iron, try bending it down so that when u use the handel it has more leverage tolift up ur sistern flush rubber and create a flow facume as we call it.
if its plastick.... u must ajust the hight of ur flush meganisem by turning the head were the arm is conected left and pushing it down and turning it right to fasen it again. this will also work for iron arm bt is un nessesery for iron arm.
ajust hight until problem is solved.
Please rate my advice thanx :]
Jul 02, 2010 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
Installed new tank. Flushed fine 2 times, then
The flapper isn't staying open long enought, try holding down the handel for a few seconds each time u flush.
Mar 10, 2010 | Home
Water level in bowl too hogh
Try bendig the float rod down so th resivor dont fill so much
Oct 19, 2009 | Elements Of Design EVWC320 EcoFlush Close...
Home Logo
93 people viewed this question
Top Gerber Blades Home Experts
Donni Steen
Tom Chichester
Are you a Gerber Blades Home Expert? Answer questions, earn points and help others
