Question about Olympus Camedia D-540 Zoom Digital Camera
D-540 broke The camera fell down from moving vehicle. Would like to open it up and fix myself.
  • 21 Answers
You cant just fix it by yourself it required a well trained technician to do the job,one more there are very high voltage inside the camera you would not believe it but theres a 300V on the flash capasitor,,,,
Posted on Feb 23, 2012
Extremely Loose steering column. Not just a little wiggle room, wheel moves up, down farther than normal tilt and left, right so far wheel touches wiper/lights/signal arms.
I believe your steering wheel is coming off take vehicle to dealership asap and don't drive. A screw or something fell out
Dec 06, 2015 | Cars & Trucks
Nikon fa advance level fell off
I can tell you that you can't fix it yourself
Mar 07, 2013 | Nikon FA 35mm SLR Camera
The shutter release button on my Nikon Coolpix s620 fell off. I have the button and the spring. Can I fix this myself?
No. you can not. FOr that you need to open the complete camera body. If you expert then you can try.
Aug 12, 2012 | Nikon Coolpix S620 - Noble Purple 2.7"...
I have a 1999 nissian altima andthe backdrivers door wont open handle moves up anddownbut wont budge
this sounds like a linkage rod fell off or the handle broke, the door panel will need to be removed from there you will be able to see whats wrong by moving the handle and looking to see if the linkage moves, you will be looking to see if the linkage fell off or if it broke at the handle.
Mar 20, 2011 | Nissan Altima Cars & Trucks
When i turn my camera on it make noise and i believe it from the lens that fell down
If your camera fell down with the lens opens chances are the rings that are around that lens that are used to secure it have been dislodged and are not doing its function anymore. With that fall, however hard it was, you most likely broke other pieces too. the only way to find out is to do a full diagnoses. They will basically take the camera apart, fix the lens and go from there. Contact www.teleplancamerarepair.com , describe what happened, camera details/make/model, and ask for a quote.
important: do not force the lens in or out for that would most likely make matters worse.
More details on the camera here would have helped too.
Jun 23, 2010 | Sony Cyber-Shot DSC-P72 Digital Camera
Door won't open from the inside
Most likely a $2 plastic clip broke or fell off the actuating rod. No site that I know of, but the library should have a service manual for your vehicle. In any case, you will have to remove the inner door panel and/or the exterior handle. Check for screws on the outside handle. If ya get lucky, you can remove the handle from the outside and fix it there. If not, remove the door panel and replace the clip and rod from the inside.
Jun 30, 2009 | 2001 Ford Explorer Sport Trac
2005 dodge durango rear hatch is down and will not open
I own a 04 durango and the door lock actuator froze up internally and I could not open the rear hatch. After hours of research on my computer nothing seemed to fix the problem. I eventually figured it out myself. You must pull the screws out of the molding on the inside of the rear door. You can now pull the molding toward you and look down at the actuator and latch. You can pull on the molding quite a bit if necessary. I never broke mine and I was pretty agressive with it. Now, on top of the whole mechanism is the lock actuator. There should be a white plastic lever sticking out towards the driver side. If you can slide it from back to forward "forward is front of vehicle", the lock should be working. If not your door is not unlocking. My durango had 3 Torx screws on top of the actuator. Remove them. This will take the actuator off of the latch. Now that the actuator is not binding or holding the lock from moving, again try to move the white plastic lever towards front of vehicle. It should click and you should be able to open the door.
Feb 08, 2009 | 1995 Subaru Legacy
Camera won't turn on
Fixed! Several people I've described the problem to asked me if I dropped the camera, and I honestly did not remember dropping it, but I could've just forgot that it happened. Later, (after this was posted) it slipped out of my hand and fell to the carpeted floor. When I picked it up, I noticed that the lens shutter had moved (to be closer together). I turned it on, and after a few automatic adjustments, the camera was working like normal again! Perhaps the same thing that broke it, fixed it!
Jan 17, 2009 | Olympus Cameras
Samsung Digimax A7
the screen is blury and i can't take good picture
Dec 20, 2007 | Samsung Digimax D53 Digital Camera
Stuck in camera mode, little switch fell off.
Has anyone tried a hard reset on their camera by removing the main power batteries for 60 seconds and the reinserting them as if it were the first time power up. This may not fix your particular problem, but when the processor that runs all of the electronic features of the camera gets confused, this is the best way to clear its confusion.
page number 114 of your manual. tell me if this works
Oct 20, 2007 | Canon PowerShot A540 Digital Camera
Olympus Camedia D-540 Zoom Digital Camera Logo
51 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
