Question about HP ScanJet 3670 Flatbed Scanner
Can not install software
I have downloaded software for my HP scanjet from HP site but the file has a dot part extension, not istall.exe (WlaYa0Hc.part).... what can I do to finally install my device?
I am trying to revive an HP 6200C scanner (as a substitute for a broken scanner in an Office Jet Pro l7580 printer). When I try to install, the computer, running XP, asks for hpsjrreg.exe. HP site does...
Hello, I've got a hp scanjet 6300c and I downloaded all the software from the hp website....and hpsjrreg.exe is included in the suite or package. Try downloading 6300c s/w and see if you get it that way. Regards, nicam49
Feb 05, 2011 | HP Office Equipment & Supplies
Driver for windows7 x64
These instructions will make your scanner work with Windows 7:
1) Go to this link and download the official Hp 5300C WinXP 32-bit drivers
2) Run the .EXE
This extracts the files to the directory c:\sj664en
3) Edit the hp53sti.inf file
Find this line:
Insert this line above it:
The section should look like:
; Win2k Models
4) save the file and exit
5) delete HP53STI.CAT
6) Install the driver
Open Device Manager
Find the HP Scanjet device in teh device tree (yellow exclamation mark no doubt)
Right click it
Select Properties
Select Update Driver
Select Browse my comptuer
Select 'Let me pick'
Select 'Have disk'
In the dialog, type c:\sj664
Two unsigned HP Scanjet 5300c drivers will appear
Click on the top one
click next
it will tell you to reboot
7) reboot your PC
8) after rebooting, try it out!
I found this worked for me in PrecisionScan 3.03 TWAIN mode only. The HP-WIA part is broken in this scenario and does not appear in the WIA manager GUI at all.
XP X64 Instructions
This is modified from a vista post, so most of the credit goes to that post that helped me make it work on xp x64.
Go to this link and download the official Hp 5300C WinXP 32-bit drivers to use with x64, the one posted on hp's site does not work.
2) Run the .EXE and then cancel the install, don't install the software, haven't been able to get it to work.
4. Find this line:
5. Change it to all of the following, all 6 lines:
%Mfg%=Models,NT.5.1, NTamd64
Don't change anything else.
6. delete HP53STI.CAT
Go to device manager and update driver or add new hardware
select the directory these files are in
and it will install or select the scanner from the list.
now install a second party scanner program and it will work the one that comes with the installer for hp doesn't work.
so any second part scanner program should now work with the drive that this installs.
Jan 24, 2011 | HP ScanJet 5300C Flatbed Scanner
My scanner hp scanjet 2400 not scan second copy
you must try and install the CD first before the system will recognise the hardware......kindly download another drive from the manufacturer site without that i won't work
Aug 23, 2009 | HP ScanJet 2400 Flatbed Scanner
Pproblem in scanjet 2300c driver downloading
Go there, download that file and save it to your desktop and run it. Since its an .exe, it'll self instal.
Jan 18, 2009 | HP ScanJet 2400 Flatbed Scanner
Unable to scan using HP Scanjet 3200C in Win XP Pro
Hi Shantala,
HP advises that, on some systems, the scanner hardware may get into an error state that will keep the scanning software from finding the 3200c ScanJet. If your scanner still isn't found after installing this driver and software update, please follow the directions below:
  1. Unplug the power cable from the 3200c ScanJet.
  2. Unplug the parallel cable(s) from the 3200c ScanJet.
  3. Shut down the PC and wait for ten seconds.
  4. Plug in the power cable to the 3200c ScanJet.
  5. Plug in the parallel cable(s) to the 3200c ScanJet.
  6. Power your PC on.
If you still have the problem, uninstall the driver from device manager, and download and run this .exe file version of the driver instead.. and if necessary, repeat the above steps..
Hope this helps
Chris (ziraffa)
Dec 22, 2008 | HP ScanJet 3200C Flatbed Scanner
Hpscanjet 5300 software problem
I'm sure SJ664EN.EXE is just the installer. Once installed there may be several applications, with one of their files named HPPRSCAN.EXE, just look in the Windows programs menu for HP.
Oct 10, 2008 | HP ScanJet 5300C Flatbed Scanner
Scanjet 3770 installation
now how can i installation thqt driver
Jul 15, 2008 | HP Scanjet 3770 Flatbed Scanner
Problem regarding installing HP scanjet 3770
I am using HP scanjet 3770 for the last 1 year. I was runing it on windows XP, but now i have installed Vista on my pc and itis not installing due to the drivers. Kindly help me in getting the software installed on windows vista. From which site i will get the drivers to download...
The specific ero: Parsing error in file C:\Program file\HP\Digital Imaging\bin\hpqscloc\1033.xml
Please Help (Ayúdame)
Apr 22, 2008 | HP Scanjet 3770 Flatbed Scanner
Hp scanjet 3400c driver download
1) Ur cd i damnged
2) U have a problem with registry
I recomended you to use this software first :
After u have used this software to clean up ur registry change the directory ( do not save installing files on PROGRAM FILES SIMPLE CREATE ONE FOLLDER AND save installation folders there)
If it wont work let me know and i will post driver for you ok?
Nov 12, 2007 | Office Equipment & Supplies
HP ScanJet 3670 Flatbed Scanner Logo
159 people viewed this question
Ben Johnson
