Question about Kyocera Office Equipment & Supplies
Taskalfa 250Ci F040
F040 Err Code
2 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Posted on Dec 22, 2010
How do i fix error code C7103
you need to replace the magenta developer unit
Sep 03, 2015 | Kyocera Taskalfa 250ci Color Copier...
How do i change the fax confirmations to come out of the side tray?
There should be a setting menu in "system settings" : Common settings , Paper tray settings.
Aug 14, 2014 | Kyocera Taskalfa 250ci Color Copier...
Error code taskalfa 500ci , c3300
C3300, AGC Error. something in the copy lamp or optical section
Jul 08, 2014 | Kyocera Task Alpha 400ci / 500ci Yellow...
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
C3300 error in kyocera taskalfa 820
I have actually discovered another cause of the C3300 error on Taskalfa machines .. Mainly the 250ci - 552ci (300ci, 400ci included) .. If you look at the mirror assembly there are 4 plastic pads that glide on the rails. I discovered 2 on the left side damaged causing the mirror assembly to sit at a slight angle .. Got these replaced and it works great!! I hope this helps!!!
Sep 11, 2012 | Kyocera Office Equipment & Supplies
228 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
