Question about RCA Cameras
Instruction Manual for 2100RP battery charger
Traction Batteries Charger
SOURCE: I had the same problem of the battery charger blinking...
You can fix this! If the battery is really low it won't communicate witht the charger... thus the blinking red light. Charger says - I see you are trying to use me, but I don't recognize this battery. The battery needs a little shot of charge so it can communicate with the charger. Put the battery in and take it out quickly a few times. This will give it the little boost it needs to be able to talk to the charger. Then, you will find, you can charge!
Posted on Jan 21, 2010
  • 374 Answers
SOURCE: Battery Charging Problem
First of all I would make sure that the battery is in correctly. There should be an arrow on the battery that should line up with a plus sign on the battery door. Once the battery is installed correctly then place the camera on the charger and the light should be a solid red. If that still doesn't work then I would be more inclined to think that you may have a defective charger. I would call Casio repairs and see what they can do to help you.
Posted on Jul 17, 2007
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Posted on May 23, 2008
SOURCE: coleman 21.6V drill - batteries
same exact problem
Posted on Oct 02, 2008
SOURCE: Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Posted on May 30, 2009
I need a charger and battery for the spiderman quad,serial number is SP 6600
This answer is a bit overdue, but the Spiderman Zoom N Go requires 2 AA batteries (no charger). The instruction manual for how to hange the batteries can be found here: http://www.hasbro.com/common/instruct/78506.pdf
Sep 01, 2012 | Hasbro Spiderman Zoom N Go Quad Cruiser
A brother of mine has a micro electric wheelchair By POIRIER. and it has a problem recharching the batteries. can I get an instruction manual on how to test and repair the charger?. it has not been used...
John the problem is probably not the charger. You don't say if you replaced the batteries if you haven't then they have to be replaced before the charger will work the charger will not pickup really low battery voltage and charge those batteries. Hope this helps
Feb 10, 2011 | Health & Beauty
I charge my jet 3 ultra with the cord but as soon as i remove the cord it dies what do I do? I no longer have the instruction manual
jaeger How long have you had the chair? And have you changed the batteries or had them changed within the last year? The problem could be the batteries. If the were run down or not charged for a long time then your charger cannot pick them up enough to reach a full charge or in your case no charge at all. Now if the batteries are fairly new but have run down the problem could be the charger. If you have a digital voltmeter and your Jazzy has an on-board charger -- plug in the charger then put the test leads in the charger port two outter plug holes under the front of the joystick set the meter to 200 volts dc. You should read up to 30 volts with the charger plugged in. Now unplug the charger and you will read the battery voltage it should read 24-27 volts. If when you have the charger plugged in and you don't read up to 30 volts then the charger is bad If after charging overnite and you don't read 24-27 volts the the batteries are bad If Medicare purchased your chair then you can call a service company to repair your chair and they will bill Medicare for the cost of the repair. Medicare will pay 80% of the cost. You can call Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have a tech come out and rpair your chair. Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
Battries are discharged and now charger does not operate
The batteries will discharge below the reference voltage required for the charger to "see" the batteries if left uncharged for more than a month or more. You have to carefully bring the batteries back up to about 12 volts each for the charger to see them. The easiest way is take them to a qualified battery shop that has a step charger for sealed batteries. If you attempt to use a car charger on sealed batteries, you will ruin the batteries or even blow them up as the cases are sealed and the gas from charging has no way to escape. Some people have used a standard car battery charger on low only, applying a charge to one battery for about 15 minutes, then the other for 15, etc. until the batteries are back up to 12 volts, but again, using a car charger is dangerous and could cause the battery to explode.
May 20, 2010 | Jet 3 Ultra Power Chair
Need an instruction manual for a Century 10 amp battery charger
Are you having this problem on a particular battery? Try using it on your car's battery with the headlights on. The headlights should brighten and the unit show 5 -10 amps charging.
A car battery can develop a problem where the battery post gets disconnected from the inside. This is common on batteries in storage or left on charge a long time or used in a car with a defective alternator. The battery is charged but it won't start a car. headlights connected look normal until you turn the key, then the headlights will just go out. This descibes a bad battery.
Apr 19, 2010 | Scosche Industries Scosche GPSCHRG...
My mother's mobility scooter will not respond even after a long charge and I can't get the cover right off to check the batteries.Can I get an instruction manual?
ok, now can you try another charger ?
It could be the batteries have decided to call it a day.
Check the wiring from the charger to the batteries and son on.
Normally the back panel is held dowb by velco,
Regards
GeWiz
Oct 05, 2009 | Health & Beauty
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
Battery &charger specifications
In addition to the batteries provided with the camera, the following types of battery can be
used. Choose the power source best suited to the situation.
AA alkaline batteries/Oxyride batteries
The number of pictures that you can take may vary considerably depending on the battery
manufacturer and shooting conditions.
AA NiMH batteries (rechargeable batteries)
Olympus NiMH batteries are rechargeable and economical. For details, refer to the
instruction manual for your charger.
(Lithium battery packs (CR-V3) and AA manganese (zinc-carbon) batteries cannot
be used.
(Power consumption by the camera varies depending on which functions are used.
(Power is consumed continuously during the conditions described below causing batteries
to become exhausted quickly.
• The zoom is used repeatedly.
• The shutter button is pressed halfway repeatedly in shooting mode, activating the auto
focus.
• The monitor is left on for an extended period of time.
• The camera is connected to a computer or printer
(The battery life varies widely depending on the type of battery, manufacturer, shooting
conditions, etc. Because of this, there may be cases where the camera turns itself off
without displaying the battery level warning, or displays the battery level warning sooner than usual
Dec 28, 2008 | Olympus FE-210 Digital Camera
No Manual?
Online Manual (PDF) For DW9116
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/630429-00,DW9116.pdf
Dewalt DW9116 Product Recall:
http://www.dewalt.com/us/articles/article.asp?ID=187
Nov 22, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Cameras Logo
440 people viewed this question
Top RCA Cameras Experts
Are you a RCA Camera Expert? Answer questions, earn points and help others
