Question about Cell Phones
Problem When i ping (-t) on the U30 from the main office
My company have NETASQ U30 & U70 on it branches connected through VPN connection to the main office to the SonicWall Firewall. i am using IPSec VPN, the setting on all of the three units are the same, U70 is functioning very well, while there’s a problem in U30 VPN connection; The issue is: When you ping (-t) on the U70 from the main office (which has SonicWall firewall) – it replies instantly without any problem, shared data opens also instantly. When you ping (-t) on the U30 from the main office (which has SonicWall firewall) – it gives request time out for couple of minutes, shared data cannot be open !! After a couple of minutes of ping (-t) it gives reply answer, as it seems the sessions opens, and then you can access shared data, if you close down the ping then wait for few minutes and ping again the issue appears again!!? It seems (in my opinion) the 3 way handshaking is taking too much time on U30, while in U70 it works perfectly. I need to help
mansnes
  • 50 Answers
SOURCE: Can't connect to AT&T VPN
I'll need to know what router you're using, make and model, for more specific help, but sometimes there is an option for IPSec passthrough. For example, on my Linksys Wireless Router WRT54G, there is a set of buttons under Security/VPN that are entitled IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough. Since I don't know what router you're using, I can't tell you wether or not your router supports such functions or not, but if it does, you need to enable them.
Posted on Mar 04, 2008
efs_perpends
  • 1996 Answers
SOURCE: Setup Issues
You might have to create a custom exception rule for Outlook.exe, but this can create compromises to your overall security.
Please see article here and here and here and here
Also be aware that 3com has a support forum online that may be of some assistance if you can't get it work.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 20, 2009
SOURCE: Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Posted on Jun 18, 2009
SOURCE: My phone keeps turning off when i turn it on....
remove your memory card and turn it on again.
your welcome
Posted on Jul 21, 2009
SOURCE: Unable to reach firewall periodically
If you are using the firewall as the DHCP server, you may need to check the DHCP lease period on the firewall & increase it if required.
Posted on Jul 24, 2009
I have two Cisco routers one is a 501Pix(located at branch Office), the other is a 515E Pix (located at main office). I've configured a vpn tunnel to the router at the main office. The router at the branch...
  1. Please check whether the Tunnel Phase 1 and Phase 2 are Up.If Not Proceed Next, if Yes Proceed to point 4
  2. Please check the peer IP is reachable
  3. Please check the configuration and the encapsulation method used
  4. Check whether in the Match Address whether the IP has been Allowed If Yes Proceed Next
  5. The Branch PIX will be in the Outside interface of the Main PIX, security Level will be enabled so do NAT. If Yes Proceed next
  6. If unable to ping enable the Inspect ICMP in the global policy to enable ping If Yes
  7. If all The above are done. please check the routes between the 2 remote computer.
Please check all the above point, surely your problems will be solved
Feb 26, 2011 | Cisco PIX 501 Firewall
How to connect my MSSQL server through VPN by using PPTP
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
Jan 20, 2008 | Cyberguard SG300 (00852503000366) Firewall
Tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
on Mar 22, 2011 | Microsoft Windows Server 2003 Enterprise...
Cannot link vpn. direct from internet provider works. when try connection via d-link dir625 does not connect. does allow internet access
Ok to Setup you VPN follow the instructions below. You can configure DI-804HV, DI-808HV, and DI-824VUP+ by web management interface. Type 192.168.0.1 (The LAN IP is 192.168.0.1 by default) in the browser, and then input user name: admin (there is no password by default) to pass authentication of web management interface. Then finish the configurations as showed below on Gateway A and Gateway B. Configurations of Gateway A 􀂾 Model: DI-804HV (DI-808HV, or DI-824VUP+) 􀂾 Firmware version: v1.40 (You can download the latest firmware on D-Link’s website.) 􀂾 WAN IP Address: 14.15.16.17 (Static IP) 􀂾 LAN IP Address: 10.5.6.1 (Subnet Mask: 255.255.255.0) 􀂾 VPN Configurations: 􀂄 Enable VPN function on Gateway A. 􀂄 Tunnel Name: toGatewayB 􀂄 VPN Method: IKE (Main mode) 􀂄 Local Subnet: 10.5.6.0 􀂄 Local Netmask: 255.255.255.0 􀂄 Remote Subnet: 172.23.9.0 􀂄 Remote Netmask: 255.255.255.0 􀂄 Remote Gateway: 22.23.24.25 􀂄 Pre-share Key: hr5xb8416aa9r6 􀂄 IKE Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 28800 􀀹 Life Time Unit: Second 􀂄 IPSec Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encapsulation Protocol: ESP 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 3600 􀀹 Life Time Unit: Second 4. Verify the VPN connection Before you start to establish VPN connection between Gateway A and Gateway B, please make sure the Internet connection between Gateway A and Gateway B is workable. You can use “Ping Test” tool on Gateway A (or Gateway B), and input the IP address of Gateway B (or Gateway A) to see if there is any response from its peer device. Connect a PC (called PC_A) to the LAN port of Gateway A, and connect another PC (called PC_B) to the LAN port of Gateway B. Start to “Ping” PC_B on PC_A, then Gateway A will start to establish IPSec connection with Gateway B. If you can get “Ping” responses from PC_B on PC_A, then it means the tunnel has been established successfully. You can also check the “VPN Status” page with web management interface to verify the status of VPN connections. Figure 1: VPN status of Gateway A after IPSec connection has been established. Figure 2: VPN status of Gateway B after IPSec connection has been established.
Hope this helps
Here it is in PDF.http://www.vpnc.org/InteropProfiles/D-Link-DI.pdf
Feb 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
Unable to get remote desk top computer to work on acer aspire one
I think you're trying to connect to your office computer from home/somewhere else.
If that's the case, make sure you have done the following :
  1. Your VPN Session is connected
  2. Your Office IT Administrator allowed RDC over VPN
  3. Your Office Computer RDC is enabled
  4. Your User (local or domain user) having administrative rights or allowed to connect to RDC session
  5. You got no firewall blocking RDC connection or remote registry
To check if you already connected to your office VPN, launch command prompt and try pinging your office computer name or IP Address. As an example if your office computer name is PC-100 and IP address is 192.168.1.100 then you will issue : ping PC-100 or ping 192.168.1.100. If you got ping reply than you're good to go.
To Enable RDC on your office computer there are 2 ways :
1. On your office computer, right click my computer > properties > Remote > Enable Remote Desktop
2. Via remote registry :
- Start > Run > Regedit > Enter/Return
- On registry editor, go to File > Connect Network Registry > Type in your office computer name > OK
- On your office computer registry, browse to : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal Server, find the key "fDenyTSConnections", double click it and change the value to 0
You should disable your windows firewall or 3rd party firewall for easier configuration. You can;however set up exception on your firewall but will need some knowledge to do that.
Hope it helps.
Nov 02, 2008 | Computers & Internet
VPN connection timed out
please tell me that who is your ISP at home?
Oct 25, 2008 | Trendware 54Mbps 802.11g Wireless AP
Can't ping or see anything on remote LAN
They are defective i have gone through like 5 or 6 of them before sending them all back i would sacrifice the gigabit and go with the RV042
May 21, 2008 | Linksys RVS4000 Router
How to configure in point-to-point
Dear,
To connect both offices you have to create a VPN between both end's so that you can make a safe data tunnel between these two office. for this you have to static IP's on both ends and a Third party VPN client software.
for more details you can mail me i'll provide you all the details for how to create a safe VPN between two points.
Cheerup
Mar 18, 2008 | Zyxel Prestige 660H Router
Not able to connect to server
The software vpn probably will not work.
Is the vpn tunnel up? Can you ping the IPO? what subnet is the pc?
Oct 22, 2007 | Avaya 4610
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Cell Phones Logo
73 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
