Question about Toshiba Satellite P205D-S7802 Notebook
What's your problem?Toshiba Satellite laptop p205d blue light flashing not powering up
Crankstart
  • 696 Answers
SOURCE: Toshiba Satellite laptop does not power - no blue light to recogn
You should NEVER see sparks when connecting the AC adapter.
If you are seeing that there is damage in either the adapter, the AC plug or both although I would suspect internal damage in the plug.
Unless your handy with a sauldering iron I think this would be a good point to take it to a pro, they can test the AC adapter with a voltmeter and confirm or deny my suspicion. If I'm wrong the voltmeter will show wrong voltage for the unit, if I'm right it will be in tolerance and you'll know the AC plug is the most likely culprit.
Depending on the model and the repair shop these typically cost about $100-$200 to repair.
Chris
Posted on May 24, 2009
  • 479 Answers
SOURCE: Toshiba Satellite A105 laptop won't boot up?
hi,
Please try the following steps
1.remove the battery and press the power button till on eminute.
2.plug in the power adaptor and check whether it is working(without battery)?
3.Refix thebattery and check.
If then also it is not working either the RAM is faulty or needs to be refixed so please oonce refix the RAM.
Thanks
Posted on Jul 06, 2009
  • 104 Answers
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
  • 121 Answers
SOURCE: Toshiba Satellite L305-S5900. No power indicator light.
sorry there is no fuse that i know of on the satellites it sounds like a motherboard issue see if it can be warranty repaired by the manufacturer
Posted on Nov 25, 2009
SOURCE: toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Posted on May 20, 2010
I need to know if the mother board from the p205d-s7436 is compadable for the s7438 model
Satellite P205d-s7436 motherboard,
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,K000056150.aspx
Satellite P205d-s7438 motherboard,
Same part number used for both laptop models.
Satellite P205d-s7436 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7436/4505-3121_7-33428376.html
Satellite P205d-s7438 specifications,
http://www.cnet.com/laptops/toshiba-satellite-p205d-s7438/4505-3121_7-32658635.html
Just by comparison of the specs the data suggests only a Processor change, Ram Memory amount, and Harddrive size.
Uses a Socket S1 processor socket on both model's motherboards,
http://en.wikipedia.org/wiki/List_of_AMD_mobile_microprocessors#.22Tyler.22_.2865_nm.29
Both models use an AMD 690V graphics chipset, (ATI Mobility Radeon X1200)
http://en.wikipedia.org/wiki/AMD_690_chipset_series
The answer is Yes.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Regards,
joecoolvette
Sep 15, 2012 | Toshiba Satellite P205D-S7438 Notebook
Black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 22, 2012 | Toshiba Satellite P205D-S8802 Notebook
Toshiba satellite p205d-s7436 will not start.
Please remove the cable and remove the battery and connect the power cable and check it. if it working remove the power cable and connect the battery and check it.
Mar 15, 2012 | Toshiba Satellite P205D-S7436 Laptop DC...
Can I remove ram from acer aspire 3003wlci to add to toshiba satellite p205d-s7454. The acer is pc-2700 and Toshiba is Pc2-5300 200 pin DDR2. Is sticking a USB 1gb readyboost the same as installling 1gb?
To answer your question, no. Those RAM types are not compatible as they are a full generation apart in terms of a RAM lifecycle.
And to answer your question about Readyboost, no. Installing a 1gb flash drive to use with readyboost isn't the same as installing an extra 1gb of internal system memory. It essentially allows Windows to use the newly added flash drive as a system cache. See more information on Readyboost here.
Thanks, and have a great day!
Oct 03, 2011 | Toshiba Satellite P205D-S7454 Notebook
Toshiba P205D-S8802 will not start up. Pressed power button, and hear the droves starting up and then stops. The screen remains black.
Hopefully you have more than 1 stick of RAM. I would remove 1 and try it again, if that doesn't work, try the other one. When it's powering up and then powering off quickly, that could also be a heat issue. Make sure all of the fans are powering on. Also you can try removing the battery, and trying with just AC power connected. Some laptops won't let you do this, but some will, and if the battery is causing the issue, it should work.
User guide can be found here, which will walk you through getting to the memory bay. http://www.retrevo.com/support/Toshiba-P205D-S8802-Laptops-manual/id/12395ag000/t/2/
If this helps, please provide a positive rating.
Jun 30, 2011 | Toshiba Satellite P205D-S8802 Notebook
Need to replace cpu battery for my P205D-S7438y
Straight from Amazon:
http://www.amazon.com/Replacement-Battery-Toshiba-Satellite-P205D-S7438/dp/B003O77162
If it's still under warranty though you can call up Toshiba and get it replaced at no charge.
Jan 02, 2011 | Toshiba Satellite P205D-S7438 Notebook
BIOS PASSWORD ON TOSHIBA P205D
contact me @ timothydjohnson@comcast.net
Jun 01, 2008 | Toshiba Satellite P205D-S7479 Notebook
Make sure the power supply is plugged into the mobo
Toshiba Satellite P205D-S7802 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
