Question about Exercise & Fitness
I have MaxPro treadmill when I start to any prog. speed change suddenly to 14KM and you change back to any speed it goes back to 14 again
Its Maxpro Treadmill
  • 3 Answers
I dont know about yours but ours has panel that will light codes to call company on. it is on bottom under lid for motor. you can check there.
Posted on Feb 23, 2012
Maxpro ts15187i
If you can find a screen for that treadmill, you should replace the entire unit. Screen must be the exact same unit and they are not interchangeable.
May 17, 2014 | Exercise & Fitness
Cyclone SX9 0 MAXPRO Treadmill
Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
God bless you
Jun 03, 2013 | Exercise & Fitness
Maxpro vibelife V815 treadmill error
go for free download: www. fitness.manualsonline. com or www. iconservice. com.
Test every connector and tight very well, see the fuse inside, see the diagram attached for reed swithc and speed sensor, clean and tight the connector very well.
run the software calibration for diagnose and troubleshooting.
Apr 29, 2012 | Exercise & Fitness
My maxpro treadmill was wroking for about 6 mins before it jumped from speed 6 to 14 then completely shut down it is now showing an E1 message. i have read a few comments other people have made with...
I am sorry for the delayed response as i was not at my desk.
This is a common problem on these treadmills.You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Let me know,once done so that we could proceed further.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 24, 2011 | Exercise & Fitness
Treadmill seems to start out OK but after maybe 2 minutes suddenly bogs down to about half speed then will stop all together if keep trying to go. If step off the belt after it bogs, it will speed up to...
hi,
check the motor and the motor controlling card. check the motor is it over heating or not. also check the speed sensor beside the motor pulley. clean the speed sensor and refix it. then test again
ok
Jan 01, 2011 | Proform iLog 750 Treadmill
Distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
May 05, 2009 | Reebok Exercise & Fitness
OVAL SPOT IN PICTURE
LCD 101, your blue device is dying in the projector. Very common problem. The blue device cant handle the heat and allowing the other colors to come thru. I suggest replacing with a dlp brand product.
Jun 22, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Exercise & Fitness Logo
121 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
