My epson stylus tx 121 doesn't print..... it says ur printer s not ready... but everything s ryt at my end.... i need some solutions
  • Cindy Wells Feb 23, 2012
    "yes my prob is solved.... thank you so much Cindy wells :)"
    You're welcome.
  • 5,129 Answers
First how are you connecting to the printer? Is it a direct USB connectionor are you using a USB hub or print server (sometimes part of a router)? If a USB hub is in use, is it a USB powered hub or a self-powered hub (AC adapter)? (Make sure that the printer has power and is turned on. Also make sure that you have printed and scanned a calibration )
If you are not using a direct connection, try a direct USB connection. Use a different USB cable and try different ports (some ports have lower power throughput than others). Make sure that you have the correct driver for your OS. (The full software is useful for other issues.) See http://www.epson.com.ph/epson_philippines/printers_and_all_in_ones/inkjet/product.page?product_name=Epson_Stylus_TX121 for the drivers.
Try uninstalling the current printer driver and then disconnect your data cable (USB). For Windows, press Start and open the Devices and Hardware control panel (Printers and Faxes in XP) from the right hand column. Right click on the printer and select Uninstall (or left click and choose Uninstall from the Menu bar). Reboot the computer and install the Epson printer driver before reconnecting the USB cable. (Otherwise you can get the OS driver that may not work as well.) Remove your data cable from both the computer and the printer and turn off both devices. Unplug the power cord from the printer and the wall outlet. Wait a few minutes before reconnecting the power. (This will reset most printers if there is an error in the printer itself.)
If you are using a print server and the direct connection worked, check the installation information for using the print server. Not all printers are compatible with certain print server drivers and you can have a conflict.
If a direct connection to any of your computer's USB ports does not work, check if other USB devices work. If not, try updating or uninstalling your USB controller (in the Device Manager for Windows - Start > Control Panel > System and Security > Device Manager, scroll down to the Univeral Serial Bus controllers). Then reboot your machine and see if the correct driver installs. Alternatively, check your computer manufacturer and see if there is an update for your USB driver.)
If the problems persist, you may have a bad USB port on the printer. Please add a comment with the type of connection between the computer and the printer.
I hope this helps.
Posted on Feb 23, 2012
Testimonial: "yes my prob is solved.... thank you so much Cindy wells :)"
SOURCE: My Epson Stylus CX5900 doesn´t
J'ai une imprimante multifonction EPSON CX5900.
sur l'ecran, on a une ecriture SERVICE REQUIRED.
toutes les boutons ne fonctionne pas.
qu'est ce que je fait.
tactikmada@yahoo.fr
Posted on Jan 31, 2011
  • 3 Answers
SOURCE: epson stylus photo tx 700
Try going Here .http://www.dvdcenter.org/downloads.htm
Your need to download
5. Epson Service Utility Tray App for CIS Cartridge sscserve.zip. at the bottom of the page.  this should solve you prolem.
Posted on Oct 01, 2010
ruwidperd372
  • 279 Answers
SOURCE: using epson stylus tx 121,
You need to install Epson Twain Driver, go to this link to download:
http://download.cnet.com/Epson-TWAIN-Scanner-Driver/3000-2118_4-10007006.html
Good luck
Posted on Feb 05, 2011
  • 160 Answers
SOURCE: my epson tx 121 printout
What probably would work the best is to take some alcohol to the roller and try to clear as much gunk as you can off of it. Might fix the problem for you.
Posted on May 03, 2011
  • 123 Answers
SOURCE: epson printer tx 121 when i start the printer it
check if power supply heats up. if not, definitely its a power supply problem brother printer cartridges
Posted on Oct 26, 2011
Epson stylus tx121
IF THE RED LIGHT IS ON EITHER IS INK OUT OR PAPER OUT
Nov 19, 2013 | Office Equipment & Supplies
My epson stylus tx121 printer has a no power on problem
Hello sir/mam, mera epson tx 121 chalte chalte achanak ruk gaya aur usme print bhi bahut slow se hota tha. Me kya karu usk lie. Pls.reply on my email: sakinabangali@yahoo.in
Jul 06, 2012 | Office Equipment & Supplies
My Epson TX 121 Printer Wont power on
is it plugged it properly? what happened to the printer the last time it turned on?
dell printers
Oct 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have an epson stylus TX110 and it was printing fine today, but then as is sent a job from adobe it prepared to print (made usual noises) but then didnt take any paper and just went quiet. I've tried...
Try purging your temp files. If it's a usb connection try a different usb port. Since it can print from scan and do a test nozzle print then it's not getting data from the pc to the printer. If a different port doesn't work either, and if purging your temp files doesn't work try it on a different computer if possible. You may need to reinstall the driver for it.
oh and make sure you don't end up with one of those 'oh duh' moments :) ... check both ends of the cable to make sure it didn't become loose or unplugged :)
Jun 05, 2011 | Epson Stylus Photo R1900 InkJet Printer
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
Epson stylus photo r300 removed print head, flushed out all nozzels with water, dried everything, reasembled everything, including the flat ribbons, two different times. After dozens of times trying to...
If an inkjet printer has not been used for some time and several print head cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 24, 2011 | Epson Stylus Photo R300 InkJet Printer
Using epson stylus tx 121, how to scan my picture so it be stored in my computer?
Good luck
Feb 05, 2011 | Office Equipment & Supplies
839 people viewed this question
jasbo
jasbo
