Question about Toshiba e-Studio163 Copier
Toshiba e-studio 160 error toner,paper,jam - Toshiba e-Studio163 Copier
    New Friend:
My Estudio 160 jam at the roll out section what can i do
Posted on Jan 29, 2014
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
  • 8 Answers
SOURCE: toshiba e studio 161
already paper jam in feeding assembly so please check any paper jam.or lubricate all drive gears
Posted on Jul 25, 2008
  • 647 Answers
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Posted on Mar 09, 2009
  • 13 Answers
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Posted on Jul 20, 2009
  • 647 Answers
SOURCE: toshiba e-studio 720 toner low message but bottle
If everything is OK, but the message is still appear, then u can clear it by following below steps:
User Function--> User--> General--> Toner Near Empty Detection -->Yes
Posted on Sep 17, 2009
Toshiba Studio e352 is in error state.
Have you cleared any paper jams, removed and reinserted the toner cartridge, cycled the system power ?
Aug 22, 2017 | Toshiba Office Equipment & Supplies
I have toshiba e-studio 2500c error code E030. No paper jam.
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON.
Nov 27, 2016 | Toshiba E-studio 2500c Color...
Toshiba ca1 code
CA1 indicates the polygon motor abnormality in laser unit.
Well, u can take out the laser unit by removing the paper tray, toner, power supply and u will see the
laser unit.
Normally, if no connectors issue, then then only choice u have is to replace the laser unit.
Sep 10, 2012 | Toshiba e-Studio 35 Copier
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
My Toshiba E-Studio 650 is displaying a paper jam in the copier. I have removed all paper jam and I have replaced sensor. What am I missing?
There are other sensors to check or verify that there is continuity in the wires of the sensor that you've removed
good luck
Apr 24, 2012 | Toshiba E-STUDIO 650 Copier
My Toshiba E-studio 650 keeps E03 which means paper jam how can I fix this?
Probably moved some sensor caused by the paper jam, the sensor looks out of place or dirty and also check the continuity of the cables.
Apr 24, 2012 | Office Equipment & Supplies
Toshiba 3510c , error code cd70
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Aug 11, 2009 | Toshiba E-STUDIO 650 Copier
I have toshiva e studio 160, three lights blinkin on panel board - paper, toner,paper jam
This is a call for service sign.
Press "Clear & 8" to check the error code.
Feb 23, 2009 | Toshiba e-Studio 350 Copier
Toshiba e-Studio163 Copier Logo
217 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
